Author Topic: hantarex mtc9000 odd problem  (Read 1377 times)
cw
  • Last login:May 03, 2025, 09:26:58 pm
  • Game over man game over
    • The Cab
« on: November 08, 2007, 04:15:27 pm »
checked tr10 -13 as per flowchart
fresh cap kit
replaced ic2
swapped out the control card
« Last Edit: November 09, 2007, 06:52:49 pm by cw »
grantspain
Re: hantarex mtc9000 will not sync
« Reply #1 on: November 08, 2007, 05:03:48 pm »
show us a pic of the prob
cw
    • The Cab
« Reply #2 on: November 09, 2007, 06:45:39 pm »
http://s172.photobucket.com/albums/w7/modessitt/?action=view&current=MTC9000.jpg
I am not sure about this being a syn issue anymore.  This is the image with or without input, and its not rastar lines...
grantspain
Re: hantarex mtc9000 odd problem
« Reply #3 on: November 10, 2007, 01:20:08 pm »
yes a wierd problem,and you get this even without a signal?
there is a resistor that causes a similar problem at r216 which is 0.33ohm,worth a check with a meter
cw
    • The Cab
« Reply #4 on: November 12, 2007, 09:48:43 am »
R216 on the neck pcb ....
18.6 ohm
  it looks to be a 20 ohm....
« Last Edit: November 12, 2007, 09:58:49 am by cw »
cw
    • The Cab
« Reply #5 on: November 12, 2007, 10:27:52 am »
just fixed it   ... the last cap job that was done on it must have been rushed... When the cap on the neck pcb was installed they did not mount it flush and the result was it being pushed in and tearing the pad.
thanks for all the help grantspain......
grantspain
« Reply #6 on: November 12, 2007, 10:30:24 am »
nice one :applaud:
