Author Topic: Problem with mala (boot with windows), no keys work  (Read 2396 times)
briktop11b
  • Last login:December 24, 2009, 12:19:33 am
« on: November 06, 2007, 09:05:30 pm »
  I had mala working great. I configured it to work with my cp, got it the way i wanted itthen set it to boot with windows. Now when it boots the i cant use anything. When i manually boot it from the mala exe it works fine it only happens when it boots with windows. I searched on here and found something about the alt key with the ipac. When it boots and its froze i can hit the alt key on my cp. It then brings up a window on top of mala that says move , minimize , close. I use the shift function on the ipac 1 + left to hit enter on close. It closes the window and mala works fine. It works if ihit alt, then enter on close but i dont want to have to do that every time i start my cabinet. Any ideas? IM running winxp, iv just restored the computer to factory settings. Thanks
diverdown
  • Last login:April 21, 2025, 03:45:48 am
Re: Problem with mala (boot with windows), no keys work
« Reply #1 on: November 08, 2007, 09:41:55 am »
I believe this is a common bug and is being worked on....
For now UNCHECK the "start mala with windows" option in mala config
create a shortcut to mala.exe and put it in the C:\Documents and Settings\USERNAME\Start Menu\Programs\Startup  directory and it should work for you
If it ain't broke give it to me...i'll soon fix that
