Author Topic: Alt button on Ipac disrupting full screen emulator  (Read 2927 times)
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
« on: November 05, 2007, 11:31:57 am »
Ok here is my deal I would like to get NULLDC (best DC emulator) playing on my cab, My cab uses a ipac as the key encoder, I also have a ps2 in my cabinet that uses the Ultimarc PSX console adapter interface. The problem is when I play on the pc and NULLDC in fullscreen when I hit the button on my arcade that is mapped to alt on the ipac it exits fullscreen and goes to the emulator shortcut for File. Do you follow me? Anyways I can't just remap the ipac keys to solve this cause if I do that then the PSX console adapter interface won't work (only works with default ipac mappings). Any help on this issue? Can I somehow disable the alt key shortcut but still use it in game on this emulator. Maybe a windows registery hack or something to turn off gui shortcuts such as alt activing menues..........
I hope that made sense any help is appreciated.
crummy
  • Last login:May 11, 2008, 03:01:58 am
Re: Alt button on Ipac disrupting full screen emulator
« Reply #1 on: November 05, 2007, 01:40:27 pm »
By default, any time you hit "alt" on a Windows application it activates the "file" menu. Some emulators override this in fullscreen mode but I guess NullDC doesn't.
One way to fix it would be just to re-bind the key from "alt" to anything else (like "m" for example).
Negativecreep0
« Reply #2 on: November 06, 2007, 11:42:04 am »
I can't simply just rebind because the console adapters only work with ipac default bindings. So If I rebind my default key on my ipac from alt to somethign else the console adapter button assigned to alt wont work anymore
Hoopz
  • Last login:Yesterday at 08:22:44 am
  • Intellivision Rocks!
« Reply #3 on: November 06, 2007, 11:49:19 am »
Microsoft has a script for turning off windows shortcut keys during games etc.  You may take a look at that or google turn off windows shortcut keys to see other options.
Gehrig
  • Last login:January 11, 2009, 12:21:06 pm
« Reply #4 on: November 06, 2007, 12:16:37 pm »
Is just the ALT key considered a shortcut?  I thought ALT+<Key> were considered the shortcuts.
crummy
« Reply #5 on: November 06, 2007, 12:20:22 pm »
Press ALT right now (in your web browser) - you'll notice that it highlights "File".
headkaze
  • 0x2b|~0x2b?
« Reply #6 on: November 06, 2007, 01:03:17 pm »
You can check out the MapLAltToV script available for download here.
Gehrig
« Reply #7 on: November 06, 2007, 08:48:09 pm »
Right.. but isn't that application driven?
