Author Topic: Sanyo 20EZV Tube Swap  (Read 1630 times)
ncflagg
  • Last login:October 25, 2025, 08:49:13 pm
  • Oh, yeah. Idaho IS right next to Iowa.
« on: November 02, 2007, 03:27:33 pm »
I've swapped a tube into my Sanyo 20EZV chassis and have one small problem left. The end of the glass tube is a quarter of an inch longer or so than the original tube and the neckboard barely hangs on to the pins. In other neckboards I see that there is a hole for the end of the tube to protrude through but not this one. Is it safe for me to drill through the end of the neckboard? I see possibly 1 or 2 circuit tracks I may have to bypass so that part shouldn't be a problem.
Kevin Mullins
    • Me on Myspace
Re: Sanyo 20EZV Tube Swap
« Reply #1 on: November 02, 2007, 03:42:47 pm »
Go for it.
Shouldn't be much in the way in that area.... just re-route it like you already mentioned.
ncflagg
« Reply #2 on: November 04, 2007, 07:26:32 pm »
I drilled through the board and bypassed one track. It worked fine. I should've used the small bit and drilled a bunch of smaller holes though.
