Author Topic: Mame running slow on above requirement computer  (Read 1639 times)
the_jasomeister
  • Last login:November 02, 2007, 03:02:19 am
« on: November 01, 2007, 03:47:51 am »
ok I'm making a mame cabniet and having troubles with my computer.
its a 2.8Ghz prosessor with onboard graphics and 512 ram and i just installed xp on it last night and when i tryed to play the lastest mame even pacman was running at about 80%.
THIS SHOULD NOT BE HAPPENING SOMEBODY HELP PLEASE =(
I narrowed it down to a few choices that could be the problem, can you guy use your expertese to help me?
- The onboard graphics card uses to much prosessor power and slows it?
- Lack of sp2 makes it slow?
- Drivers need updating?
- Some unknown setting in mame makes it use to much cycles?
Can you please help because I don't want to but a new video card if its not the problem.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Mame running slow on above requirement computer
« Reply #1 on: November 01, 2007, 06:21:44 pm »
I just tried Pacman on Mame .120 on a 3.2 Ghz P4 that has onboard video and it ran 100% no problem.  Have you monkeyed with the mame.ini file any?  Is your computer running slowly with other apps?  Why don't you try a pre-video-rewrite version of Mame and see what you get?  Say Mame version .105 or less.
the_jasomeister
« Reply #2 on: November 02, 2007, 03:02:19 am »
thanks for the help but last night i figured the only difference waws the graphics card so i took the one from my computer and put it in it and it works fine. now i just need a better one for my comp =(
XyloSesame
  • Last login:September 17, 2024, 05:57:04 pm
  • the creepy prince guy...
    • The Nightingale Theater
« Reply #3 on: November 02, 2007, 10:29:49 am »
Dragnit has some misc cards in B/S/T
northerngames
  • Trade Count: (+18)
« Reply #4 on: November 03, 2007, 02:04:20 pm »
also if your onboard is 64mb it takes 64MB away from your ram when onboard is used
