Author Topic: NeoRAGEx 5.0 Zinc with mamewah  (Read 10704 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« on: October 30, 2007, 12:13:01 pm »
Hi guys iv been trying to run NeoRAGEx 5.0 and Zinc with Mamewah with no success and have instead opted to have short cuts to the various zinc games on my desktop and a short cut to the NeoRAGEx 5.0 exe. Only problem is that this is a real pain in the ass if I want to play them as I have to escape from mamewah and get my mouse out from behind cab and double click on each game and repeat process each time I change game.
Is there a way of getting these programs to work with mamewah or because of the way these programs are is it just not possible? thanks guys hope you can clear this one up for me.
gonzo90017
Re: NeoRAGEx 5.0 Zinc with mamewah
« Reply #1 on: October 30, 2007, 01:20:19 pm »
There's a way with Zinc, but I have no idea how.  ;D
NeoRageX is impossible to run through any frontend. Any reason you're using it? I would recommend you use Nebula instead. It runs at 60fps on my old 400mhz pc. It can be run from the command line also. To create a rom list just download the a dat file http://www.logiqx.com/Dats/ here's my ini file if you're interested.
### nebula.ini (mamewah v1.62) ###
emulator_title                            Nebula
### List Generation Settings ###
rom_path                                  E:\videogames\nebula\roms
rom_extension                             zip
dat_file                                  C:\videogames\Nebula\Nebula.dat
nms_file                                  auto:[emuexepath]\[emuexename].nms
catver_ini_file                           auto:[emuexepath]\catver.ini
list_generation_method                    rom_folder_vs_dat_file
### Execution Settings ###
pre_emulator_app_commandlines             C:\videogames\Xpadder\xpadder.exe nebula {nowait}{autoquit}
emulator_commandline                      C:\videogames\Nebula\nebula.exe [name]{nodosbox}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       E:\videogames\glaunchsnaps
movie_preview_path                        E:\videogames\videos
movie_artwork_no                          1
enable_fuzzy_search                       0
history_dat_file                          auto
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                movie
movie_path                                E:\videogames\videos
movie_fullscreen                          1
quit_delay                                0
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              0
Marky_1979
    • Personal Webspace
« Reply #2 on: October 30, 2007, 02:43:31 pm »
Thanks buddy I use neorage as it runs the metal slug series and snk vs capcom that Iv not seen work on any other emulator. In saying that I did originally download all this stuff a few years back. Do you know if all my SNK roms will work with nebula and is it hard to set up?
« Reply #3 on: October 30, 2007, 02:51:03 pm »
There's a hacked version of Kawaks that runs those games...
Marky_1979
    • Personal Webspace
« Reply #4 on: October 30, 2007, 03:11:31 pm »
Which ever is easiest to set up I have also altered my button configuration from standard mame so I will need an emu that I can alter button configs on. My mamewah is perfect at moment apart from not having zinc and snk roms working so a guid for zinc and this nebula would be ace.
« Last Edit: October 31, 2007, 06:23:32 am by Marky_1979 »
gonzo90017
« Reply #5 on: October 31, 2007, 01:44:10 pm »
There's a tutorial here http://www.mameworld.net/easyemu/
I've attached an ini file for Mamewah. In order to generate a game list correctly you need dat fille. It's also included just place inside your nebula folder and modify the ini file to point to it.
Marky_1979
    • Personal Webspace
« Reply #6 on: November 01, 2007, 01:05:06 pm »
Hi buddy have been trying to get nebula working without much success I have tried loading one of my snk roms Metal slug 5 i placed it into rom folder but it doesnt recognise its there.
gonzo90017
« Reply #7 on: November 01, 2007, 03:08:09 pm »
Metal Slug 5 doesn't seem to be supported.  Are you having problems with other roms as well?
Hoopz
  • Intellivision Rocks!
« Reply #8 on: November 01, 2007, 03:19:55 pm »
Metal Slug 5 is working in Mame now too.  FYI.
Marky_1979
    • Personal Webspace
« Reply #9 on: November 01, 2007, 04:10:08 pm »
Yeah having problems with metal slug 5 and snk vs capcom the main reasons I was using non mamewah friendly neorage is there a mamewah friendly emu that can support these games? and one I can customise button configs?
gonzo90017
« Reply #10 on: November 02, 2007, 12:43:53 pm »
The only other one I know of is Winkawaks http://cps2shock.retrogames.com/download.html Only problem is you need to use a wrapper for it  to work properly through Mamewah. And the only way to exit is by pausing  the emulator (ENTER) then pressing  Alt+F4. It isn't a problem for me since I use usb gamepads along with xpadder or joytokey. http://forum.arcadecontrols.com/index.php?topic=57045.msg561021#msg561021
Marky_1979
    • Personal Webspace
« Reply #11 on: November 02, 2007, 06:49:29 pm »
Yeah that sounds a bit tricky especially as I dont have access to keyboard from cab not without a lot of messing around. Thanks for suggestion guess i'll see If I can get zinc working in mamwah if i manage that then its a result and id be happy with that.
Marky_1979
    • Personal Webspace
« Reply #12 on: November 05, 2007, 05:05:17 pm »
Right im having major problems here can someone who has managed to get zinc working in mamewah please put up an idiots guide for me the idiot who cant get this sorted.
superart
  • Permanent ban
  • Last login:April 29, 2008, 07:16:11 pm
  • Permanent ban
« Reply #13 on: November 05, 2007, 06:07:53 pm »
edit
« Last Edit: April 29, 2008, 01:02:42 am by Suits00 »
Marky_1979
    • Personal Webspace
« Reply #14 on: November 07, 2007, 08:03:58 pm »
Cheers buddy I'll give this a shot and see how I fair.
Marky_1979
    • Personal Webspace
« Reply #15 on: November 07, 2007, 08:26:15 pm »
**UPDATE** Great news I managed to get mamewah to recognise Zinc and create a games list but when I press 1 to launch a game nothing happens Iv tried it on all the games in my list, any suggestions about what I need to do?
### zinc.ini (mamewah v1.61) ###
emulator_title                            ZINC
rom_path                                  C:\ZINC\roms
rom_extension                             zip
dat_file                                  C:\ZINC\zinc.dat
nms_file
catver_ini_file                           C:\ZINC\catver.ini
list_generation_method                    dat_file
emulator_executable                       C:\ZINC\zinc.exe
commandline_format                        [name]{autodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]{autodosbox}{nosafelaunch}
alt_commandline_format_2                  [name]{autodosbox}{nosafelaunch}
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path
artwork_2_image_path
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]{nodosbox}{nosafelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable
app_1_commandline_format
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
music_path
lcd_fe_text
current_list                              0
Zebidee
  • Online Online
  • Last login:Today at 11:47:07 pm
« Reply #16 on: November 10, 2007, 08:50:30 pm »
Marky,
The reason it doesn't work from Mamewah is because you are not passing a [name] parameter (which mamewah gets from the zinc.dat file) to tell zinc what game you want to play. eg:
c:\zinc\zinc.exe [name]{nodosbox}{safelaunch}
Also you should not use {autodosbox} with anything but mame.
Finally, why not save all this trouble and just download the Zinc setup files I have just reposted on this forum  here :cheers::
http://forum.arcadecontrols.com/index.php?topic=73330.0
Are you using mamewah 1.61?  The mamewah zinc files I posted are for 1.62b9+, and there are some minor config file formatting differences to be aware of.  No big deal though.
Marky_1979
    • Personal Webspace
« Reply #17 on: November 11, 2007, 02:11:01 pm »
Hi mate yeah I use version 1.61. I must admit I dont understand how mamewah works and the ini system is a nightmare to configure for me. I have tried to do what you said but still I cant get it to work and I know that im probably mis understanding what your trying to explain to me. I have typed in what you said verbatim but still no joy.
Zebidee
  • Online Online
« Reply #18 on: November 11, 2007, 06:17:58 pm »
Marky, as a suggestion, you could make life easier and get better support if you update to the latest software first.  The whole Mamewah config system and command syntax has been changed.  People like me may have trouble trying to remember how old software works.
I recommend that you download the latest MAMEwah (v1.62b13) from jcrouse's site and use the files I posted in the other thread.  It should work very easily then.
http://mamewah.mameworld.net/downloads.htm
For mamewah 1.61 this will probably work but I can't test it.  The following assumes that you are using the "zinc.dat" and properly generating a game list with full game names.  It also assumes that you are using the controller config files I posted earlier.
In your zinc.ini for Mamewah, Change your emulator command line to read (cut & paste):
emulator_executable                       c:\Zinc\Zinc.exe
Then change the command line format (next line) to read (cut & paste):
commandline_format                        [name] --use-controller-cfg-file=c:\zinc\ini\[name].ini{nodosbox}{safelaunch}
If that doesn't work, then update mamewah to the latest version and try again.
« Last Edit: November 11, 2007, 08:42:00 pm by Zebidee »
Marky_1979
    • Personal Webspace
« Reply #19 on: November 11, 2007, 07:47:38 pm »
Hi buddy iv upgraded to latest mamewah but it seems a lot different to the version im used to I cant change window size and on my old version I ran a snes, genesis, nes, gba emulator but cant see where I need to put the ini files to get these to run. Sorry to be a real pain in the ass but i will get there in the end.
« Last Edit: November 11, 2007, 08:28:28 pm by Marky_1979 »
Zebidee
  • Online Online
« Reply #20 on: November 11, 2007, 08:49:06 pm »
... upgraded to latest mamewah but it seems a lot different to the version im used to ...
This is also why it is hard to comment on the older version of mamewah.
I can't test it, but I noticed that the commandline_format for 1.61 above had a syntax error - an extra space :banghead:  so I edited the post and removed the offending space.  You could try cut&pasting that again with your old setup to see if that works.
Zebidee
  • Online Online
« Reply #21 on: November 11, 2007, 08:57:37 pm »
And if that doesn't work, try 1.61 without the controller cfg parameter
commandline_format                        [name]{nodosbox}{safelaunch}
Also, make sure that you look in the "mamewah.log" file to see what is really happenning.
« Last Edit: November 11, 2007, 08:59:33 pm by Zebidee »
superart
  • Permanent ban
  • Permanent ban
« Reply #22 on: November 11, 2007, 09:46:01 pm »
edit
« Last Edit: April 29, 2008, 01:03:19 am by Suits00 »
superart
  • Permanent ban
  • Permanent ban
« Reply #23 on: November 11, 2007, 09:56:58 pm »
edit
« Last Edit: April 29, 2008, 01:03:42 am by Suits00 »
superart
  • Permanent ban
  • Permanent ban
« Reply #24 on: November 12, 2007, 02:09:55 pm »
edit
« Last Edit: April 29, 2008, 01:03:54 am by Suits00 »
Zebidee
  • Online Online
« Reply #25 on: November 14, 2007, 07:29:05 pm »
Suits00, you are very helpful but it's probably best for you to just refer to the thread where I originally posted those files, rather than posting them repeatedly.  It causes confusion (multiple threads) and duplicates files on the server.  Also, I deserve my 2 cents worth of credit for going through each game and working out all the controls and writing those INI files in the first place.
Cheers, Zeb
superart
  • Permanent ban
  • Permanent ban
« Reply #26 on: November 14, 2007, 08:58:30 pm »
edit
« Last Edit: April 29, 2008, 01:04:09 am by Suits00 »
Zebidee
  • Online Online
« Reply #27 on: November 14, 2007, 10:07:12 pm »
Zinc brother, more the merrier!  I certainly don't know it all, and don't be dissuaded from posting.  Just trying to minimise confusion with multiple file postings!  What make me happy is everyone being happy :D
It's all about having fun ;)
