Author Topic: Software settings for trackball  (Read 1661 times)
bluevolume
  • Last login:July 22, 2019, 12:14:32 pm
  • I wish I'd bought more pins...
« on: October 27, 2007, 10:59:53 am »
I'm going through my machine and trying to get all of the controls dialed in.  I'm having trouble with the trackball though.  There are a lot of options and I'm not sure what the recommended settings are.
Should I change the 'mouse speed' in Windows?  I tried this but it has made the pointer jumpy when using Windows.  I've tried changing the 'digital speed' and 'sensitivity' I believe in MAME, and now I think the trackball is too sensitive.
The main use of the trackball is Golden Tee for me, and while I don't want people to have to get a running start and smash their hands into the monitor, I also don't want to take the skill out of it by having it too easy to hit long drives.  There seems to be this give and take with the other TB games, like Shuffleshot; if I get the settings right for one, the other is way off.
SABRECADE LIVES ON
kiddk1
  • Last login:August 01, 2022, 10:58:08 am
  • HAP KI DO
Re: Software settings for trackball
« Reply #1 on: October 28, 2007, 10:20:31 am »
I think there are settings for either "all games" or "this game" for golden tee just choose this game and adjust it to your liking.
Its easy to like someone,
If you dont know them very well.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: October 28, 2007, 10:34:17 pm »
No, it won't effect mame (assuming you are using XP or Vista).
You don't need digital speed, it's if you were using digital inputs, such as buttons instead of a real analog device.
So set sensitivity to your likings.  Since their are a dozen TBs and spinners, and hundreads of games that used TBs or spinners, and thousands of PC mice, it's impossible to have one fixed sensitivity value that will work for everyone on every game.  FYI, the default sensitivity value for each game is usually set to the best value that works for the developer of the game's driver in mame, and most of them have a standard PC mouse AFAIK.
One game's sensitivity shouldn't effect another game's, unless you try to set them to the same number.  It doesn't work that way.  You'll have to set each game to it's own sensitivity value (especially if the arcade hardware was different).
Robin
Knowledge is Power
Major Rock Hardy
  • Last login:April 29, 2013, 06:51:45 pm
  • xybots rocks!
« Reply #3 on: October 28, 2007, 10:59:29 pm »
This might provide a starting point:
http://wiki.arcadecontrols.com/wiki/Spinner_Turn_Count
see the bottom of the page for trackball stuff.
