Author Topic: Vector Magic from Stanford (creates vector images from bitmaps)  (Read 13461 times)
fixumdude
  • Last login:July 23, 2021, 10:02:08 pm
  • Getting Better at Arcade Controls
    • Arcade Controls
« on: October 26, 2007, 02:04:05 pm »
This looks pretty amazing!
http://vectormagic.stanford.edu/
Has anyone tried this on any arcade artwork yet?  If so, how is the quality?
Re: Vector Magic from Stanford (creates vector images from bitmaps)
« Reply #1 on: October 26, 2007, 02:12:41 pm »
I just uploaded the jpg of an old Zork map that Mr C posted... let's see how it does with all of those hand drawn curves.
Edit: the results
« Last Edit: October 26, 2007, 02:34:33 pm by ChadTower »
XyloSesame
  • Last login:September 17, 2024, 05:57:04 pm
  • the creepy prince guy...
    • The Nightingale Theater
« Reply #2 on: October 26, 2007, 02:44:08 pm »
Edit: the results
Better results than I had expected to see, but still quite a bit of cleanup needed for a hand-drawn original...
« Reply #3 on: October 26, 2007, 02:45:03 pm »
Yep.  Look at it this way... it's a scan of a hand drawn original from 25 years ago that was never drawn with this in mind.  That's pretty good.
XyloSesame
« Reply #4 on: October 26, 2007, 02:56:53 pm »
Agreed. I would expect it to choke on the text, but the strokes look very good.
Has anyone tried the crappy Illustrator Live Trace on this for comparison?
« Reply #5 on: October 26, 2007, 03:03:10 pm »
One thing that should be noted is that I chose this because it is high contrast without any gradients.  Tons and tons of lines but easily detectable.  We should try something more photo-like next.
FrizzleFried
    • Idaho Garagecade
« Reply #6 on: October 26, 2007, 06:20:54 pm »
I just processed the MULTIPEDE logo I got that was relitively low res...
...lets just say I'd likely use the vector this website made over the original I submitted!
This...my friends...ROCKS...eliminates HOURS of work!
billf
  • Last login:September 14, 2022, 05:53:05 pm
  • Why ya dog-gone crazy idgit!
« Reply #7 on: October 26, 2007, 06:26:32 pm »
The Vector Magic site does have a comparison page where they compare their conversion against Adobe and Corel.  The Vector Magic conversions do look pretty amazing and true to the original image.  Here is the link to the comparison page:
http://vectormagic.stanford.edu/vectorize/comparisons
Chad - they do have samples of a few photos that were vectorized.
« Reply #8 on: October 26, 2007, 07:15:49 pm »
They do but there's no telling how many passes those samples took, or how large a sample it was they were taken from... definitely better to test with our own images than to trust their examples.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #9 on: October 26, 2007, 08:29:06 pm »
Just my luck ... down for maintenance  :-\
zorg
« Reply #10 on: October 27, 2007, 06:26:41 am »
My god we will see a lot of crappy vector trace poping out  :dunno
thoose tool must be used knowing their limitation :D let see what wil happens.
I'm on the planning stage
mcfreak
  • Last login:March 01, 2021, 01:55:04 pm
  • Asteroids moving along...
    • Hobby Blog
« Reply #11 on: October 27, 2007, 08:45:00 am »
My brother has a US Dirtfox with World Rally side art and there isn't anything out there for dirtfox except the flyer.  I converted a small graphic I found and it turned out pretty good.
http://vectormagic.stanford.edu/vctr/vctr_flex?g=14956&k=C6hEPpaq1bRsevw1&p=g
FrizzleFried
    • Idaho Garagecade
« Reply #12 on: October 27, 2007, 11:05:08 am »
Zorg...surprisingly the result of this tool is DAMN GOOD ... easily 90% of the work is done for you.
Here is a MULTIPEDE marquee I did...it's original size was maybe medium res....
http://vectormagic.stanford.edu/vctr/vctr_flex?p=g&k=EP9SHFjSjBfkmE3I&g=15599
Here is a Xevious marquee I just did.  It was originally a 70K file pulled from MAWS...in other words,  its about as low res as yer gunna get...and the conversion is't great....so real low res stuff it aint gunna help too much...
http://vectormagic.stanford.edu/vctr/vctr_flex?g=23644&k=MDoOEdqcJTtMjilc&p=g
...and don't forget to zoom in on these images to see what the REAL benefit of this tool is.
« Last Edit: October 27, 2007, 11:21:51 am by FrizzleFried »
WunderCade
« Reply #13 on: October 27, 2007, 12:51:58 pm »
This program could do wonders with a high-res (no flash reflection) scan of classic arcade side-art. Makes you wish you could go down to Wally-World and buy a 72" x 36" flatbed scanner.  ;D
A lot of people must be tinkering on the site now as it's server doesn't seem to be keeping up.
« Reply #14 on: October 27, 2007, 04:04:22 pm »
It has a pretty small max filesize, you know.  The file I put in was like 475k and it reduced that before it started the work.  To do full sideart it would have to be done in a ton of small chunks and stitched together manually.
FrizzleFried
    • Idaho Garagecade
« Reply #15 on: October 27, 2007, 05:02:34 pm »
Chad...it's vectorizing.  Send it whole side art at 10 megapixel and it will convert to a vector that can be scaled with zero degradation.   You then scale it to HUGE size and save it as a raster image.  Then go in with photoshop and fix it up a bit.  Send that file to MAMEMARQUEES and you are good to go.
« Reply #16 on: October 27, 2007, 07:12:41 pm »
It reduced the source image when I uploaded it.  That has potential to blur the image, depending on how good their algorithm for filesize reducing is... and of course, when you reduce source quality you reduce output quality.    If you send it whole side art at 10 megapixel it will reduce that giant file down to something like half a meg if that.  That's what it appears to want to do, anyway, and a 10 megapixel full sideart reduced to half a meg would look like oatmeal before the vectorizing even started.
bfauska
« Reply #17 on: October 27, 2007, 11:49:40 pm »
But for people who do know the limitations, the system will save hours of time and leave you with an image that needs touch-up not full vectorization.  The bus may not get me ALL the way to work, but it still beats the hell out of walking the whole way.
WunderCade
« Reply #18 on: October 28, 2007, 12:02:38 pm »
Hmm...I just took an image (SF Chun Li) from the WIP string, It didn't translate that well to vector, although it did get alot of the detail:
Here: http://vectormagic.stanford.edu/vctr/vctr_flex?p=v&k=elTdngOmOnvR9VMtD7oIUpTKK2DfCIlh&v=26086
« Last Edit: October 28, 2007, 12:06:35 pm by WunderCade »
zorg
« Reply #19 on: October 28, 2007, 12:12:30 pm »
I let you experience the difference of time needed to <i>touch up</i> versus from scratch hand vectorisation, and we'll speak about the utopical time gain.
WunderCade
« Reply #20 on: October 28, 2007, 12:18:39 pm »
Just FYI....the File Size Max for that site is 8 Megapixels.
It did an impressive job with the Anniversary Pac-Man Logo on the AAL Unclean Section:
http://vectormagic.stanford.edu/vctr/vctr_flex?p=v&k=1dViz0FKxSe2lJHJgpcvx5qle4wgvQtA&v=26280
« Last Edit: October 28, 2007, 12:31:21 pm by WunderCade »
« Reply #21 on: October 28, 2007, 04:11:57 pm »
8 megapixels is not a file size.
I put in a ~475k file... it reduced it before starting to vectorize.  That is what I saw.
WunderCade
« Reply #22 on: October 28, 2007, 05:30:44 pm »
 :dunno Chad.....this is the message I got:
Error: Image size is too large. Your image is 21.0 megapixels, max allowed upload size is 8.0 megapixels.
Please try another file.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #23 on: October 29, 2007, 04:21:21 am »
Megapixels is not a filesize. It would mean they capped the resolution/size of the image (Note how the message speaks of "image size" and not "file size")
Image size and file size are different things. As an example, I tried and squeezed a 21 megapixel image in a 144kB file.
zorg
« Reply #24 on: October 29, 2007, 05:23:43 am »
just a simple test in order to see how automatic versus manual will perform.
I choose a really difficult task to perform :D
a solide red square, a solid red circle (perfect one) and a smooth shape. each shape have a solid black border.
reminder: to produce a perfect circle in vector format you  only need 4 points, same rule apply for the square.
let see how the auto tool can trace it.
I uploaded the file  and played with the settings.here's the result
if at this point you don't see difference, well I will not try to convice you, but I think you should go (err run) to the ophtalmologist closest to you
now let check more deeply, just a comparison about the square and the circle.
LOL did you remind how points are needed to produce a circle ?? and a square.
Also plase notice that the square is not really square, is it ??
regarding the circle, I let you count how much are need with the auto crap
but this is not the whole crap we obtain with this kind of tool.
if you want to cry, take a look at the whole result using the following. select everithing(ctrl-A), hit ctrl-Y and take a look. lots and lot and lots of anchor points....
this was a simplistic example, imagine the result with a more complex art.
my conclusion: CRAP
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #25 on: October 29, 2007, 07:08:04 am »
Zorg,
I think you might have used the tool incorrectly. I tried some parts of the Galaga bezel and the results looked great. Not directly usable, but correcting the result sure takes a lot less work than drawing from scratch.
I used anti-aliased logo, medium resolution, less than 12 colors and this was done on low (high gave too many artifacts) I tried a more detailed section like the planet and that needs to be reprocessed on high.
The vectorized version may not look 100% identical, but it's so close that I would almost say "who cares?" I have several scans of (parts of) the Galaga bezel and they are not identical either.
In my example, I'd say the vectorized version is actualy better looking than the bitmap and it will scale to a print a whole lot better too.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #26 on: October 29, 2007, 08:04:28 am »
Ehm, you're comparing a low res poorly scaled jpg version of the result with a a low res jpg of your upload.
Here is my result:
Maybe you should try to use the tool properly before you dismiss it.
I found it had some problems with the black edge you put around the objects, but I'm sure that to fix this result to look like an exact copy it would take less than 10% of the time it would take me to draw the whole example exactly the same by hand.
zorg
« Reply #27 on: October 29, 2007, 08:15:45 am »
hummm
just by looking at this I notice the following problems.
anyway I'm (unfortunatly) pretty sure a lot of auto traced vector will pop out
FrizzleFried
    • Idaho Garagecade
« Reply #28 on: October 29, 2007, 09:17:25 am »
Considering I have ZERO experiencing in tracing,  this tool is a godsend... for anyone who knows what they are doing,  it's likely not as big a deal as it is for us newbs.
Mr. Do over at mameworld seems like he "gets it"...and will be using it as a starting point for some of his future artwork...
zorg
FrizzleFried
    • Idaho Garagecade
« Reply #30 on: October 29, 2007, 09:38:28 am »
Nope...he posted that after my last visit there...
Compared to his 99.8% accuracy of his own work I guess you are right,  this isn't anywhere near that...but for those with no knowledge of Illustrator,  it's something.
zorg
« Reply #31 on: October 29, 2007, 10:14:08 am »
then make yourself a favour, grab the Frostillicus tutorial and start playing with illsutrator instead of relying in auto trace tools
PS this is not directed to you, but to "those with no knowledge of Illustrator" :D
PS2 some years ago, before reading the tutorial I even did not know a software called illustrator :D
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #32 on: October 29, 2007, 10:44:18 am »
hummm
How much time does it take to fix those few errors as opposed to drawing the whole thing yourself?
To be honest, out of the things you circled only the ones in the nose and eyes would really be errors and the others would be up for de discussion. You can't be sure that they are wrong. You would just be guessing that it might have been different, but it might also be that the software was right.
Those few minor vectorizing errors are really only detectable by someone with a magnifying glass and the original bezel. Besides , I will say again, that I have several scans/pictures of the bezel and none of them are the same.
Another scenario is someone wanting to print that bitmap. Someone who has no desire/time/skills to vectorize the whole thing to minute detail, but who wants a bezel that looks good and fits in with the vectorized art that he already has.
The bitmap itself has a lot more and much more obvious flaws (the whole thing is noisy, has incorrect colors and it's fuzzy)  So if someone is simply thinking of printing that bitmap, which would look better in print: that original bitmap, or the vectorized result?
This software can save a tremendous amount of time in vectorizing art. At the very least or it can help in scaling/printing bitmaps for people who don't feel the need for a pixel perfect copy of the art, but who do want it to look "tight".
:edit: also don't forget that the scan that you get is imperfect itself. I redid the Galaga sideart, because the version done before was vectorized just fine, but it was based on a very distorted picture.
The best (complete) scan of the Galaga bezel I have is the one from localarcade. This image has been digitally cleaned up though. This means that a lot of detail has already been lost (stars are gone, the blue nebula are eroded etc etc ). I have been trying to fix that from other pictures, but that takes a huge amount of time and it's keeping me from finishing the thing. So at a point you have to say it's as good as it gets.
It's never going to be perfect anyway and even perfect means something else to every person. Some people will clean up edges and improve on the original (which were done in haste, low budget and thus poorly). Other more purist vectorizers will vectorize to the pixel and copy that one example they got a scan off (which might have printing errors to begin with too) and introduce errors that in fact need to be corrected.
« Last Edit: October 29, 2007, 11:14:10 am by patrickl »
fixumdude
    • Arcade Controls
« Reply #33 on: October 29, 2007, 11:06:58 am »
I agree with Zorg, that there is nothing that compares with hand tracing, and probably never will be.
But if you need some artwork for your cabinet and can't talk someone talented like zorg into redrawing it as a vector for you, and don't want to spend the time learning illustrator, etc., then this could be a passable option for you.  As patrickl said, if you just want some artwork for your cab and all you have is a grainy 300K bitmap, then this might be good enough for you, not necessarily everyone else out there.
I'm not suggesting that everyone start uploading their results to the arcade art library by any means.  It's just one more tool in the arsenal.  I don't think we need to divide the community into the anti-auto-vector and the pro-auto-vector groups.  Can't we just see this a tool, like many others, that some people will use correctly to create beautiful vectors that others will want to use.  And some will use it incorrectly to create crap, but if it works for them, and they are not forcing others to use the results, then what is the big deal??
« Reply #34 on: October 29, 2007, 11:10:35 am »
I think the best use of this is for doing things that aren't reproductions... take a picture of a car and run it through this tool... boom, you have a reasonably vectorized car you can tweak a bit and call art.  There's no right or wrong there, only making it look good to yourself, and being able to do that from a jpg in a short amount of time like this is tremendous.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #35 on: October 29, 2007, 11:17:10 am »
But then what's keeping "vectorizers" from using this as a starting point?
I'm not saying it should replace handwork either, but it will save a lot of time and in the end it would result in more art being done in the same amount of time.
« Last Edit: October 29, 2007, 11:18:47 am by patrickl »
fixumdude
    • Arcade Controls
« Reply #36 on: October 29, 2007, 11:36:56 am »
Patrickl,
I agree, that for someone who knows what they are doing in illustrator, etc. AND understands how to configure/use this tool, it would be an awesome starting point!
I have used autotrace, where it did take longer to fix all of the mistakes than it would have to draw the artwork from scratch...so you have to know how to use the tool to get the best starting point, or else you are not saving yourself any time.
But judging from some of the samples people have been posting here, it looks like this blows away adobe's autotrace, corel trace, etc.  I think it would definitely be a great jump start for a lot of projects!!
WunderCade
« Reply #37 on: October 29, 2007, 12:40:18 pm »
This would be a great ROUGH DRAFT TOOL for vectorizing then? Followed by a hand trace correction? I'm wanting to learn AI.
« Reply #38 on: October 29, 2007, 12:46:16 pm »
That's the debate... it really depends on the person doing the work and the image being used.  Some will be more work to correct than to do from scratch... others will be done quite well and only need minor correction.
zorg
« Reply #39 on: October 29, 2007, 01:19:32 pm »
quality versus quantity
