Author Topic: Mala Errors  (Read 2772 times)
stevemartins
  • Last login:December 09, 2007, 11:59:05 pm
Mala Errors
« on: October 22, 2007, 04:24:12 pm »
I posted this in the mail forum but one of the members suggested I post it in here. Hopefully you guys can help.
I've been having trouble with errors on Mala. I've only downloaded the program a few days ago so I'm still getting familiar with it but I can't seem to figure this one out. I have Mala set to automatically run when the computer turns on. The problem is, 90% of the time I get this error message when Mala attempts to run after startup:
Mala.exe has encountered a problem and needs to close. We are sorry for the inconvenience.
After I close I can reopen Mala without problems.
The only way I can seem to prevent the error is that Mala must be running when I shut down and I have to manually shut down by clicking the start button and selecting shut down, even then I still sometimes get the error when I turn the computer back on and Mala attempts to run.
This is a problem because I would like Windows to be hidden when I install this computer in the cabinet. If i have to shut down Mala everytime I boot then reopen it to get the program to run then it kinda kills the whole "hide Windows" theme I'm going for. Ideally I would like to open straight into Mala and have the comptuer shut down when I close Mala Or shut down by pressing the power button that will be relocated on the outside of the cabinet somewhere. Problem is, I get the error message above the next time I startup when I try to shut down using either of those methods. As stated before I can only prevent this by manually shutting down windows through the start button (while Mala is running) which then exposes windows  Can anyone help me out with this problem?
SonicSlammaster
  • Last login:December 29, 2009, 07:00:14 am
Re: Mala Errors
« Reply #1 on: October 22, 2007, 05:12:37 pm »
which method are you using to start up with windows? The best one is a shortcut in the start up folder and if that is your method have you refreshed the shortcut?
loadman
  • Moderator
    • MaLa
Re: Mala Errors
« Reply #2 on: October 23, 2007, 08:07:41 pm »
In any case I would enable debug logging in the options-help and credits tab.
Then post the relevant section of the mala.exe.log to Swindus via the website
Here:
http://mala.arcadezentrum.com/bugreport.html
