Author Topic: Replacement Yoke Connector/Wires?  (Read 1262 times)
GIjoe
  • Last login:August 09, 2011, 08:30:30 pm
  • GO JOE!!!!
« on: October 21, 2007, 12:45:40 am »
Hey all,
I was working on a K7000 chassis the other day that needed a yoke flip. Forcing the Blue/Red down at angle, I cracked the connector a bit. After fidgeting around with the darn thing for another 10 minutes, I managed to completely break the away the surrounding plastic leaving me with the loose wires. I would like to think the connector was brittle and the faults not all mine but I was sure someone would post otherwise  :D
Are replacement yoke wires with the connector already attached available anywhere?
Thanks,    - Joe
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Replacement Yoke Connector/Wires?
« Reply #1 on: November 13, 2007, 10:48:38 pm »
in 25+yrs of tv servicing, never had a replacement yoke w/out the leads....
u might watch on trash day for junk (i.e. donor) tv's-comp monitors . u may well find the connector
u need . or just solder leads direct to pcb.
note: the typical a63 xxx crt will work in most monitors.  may need to use spacers as some mouning tabs are reversed .  but the price is right !!
qrz
