December 04, 2025, 11:44:37 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Well, that was weird. Outage sorted out. Thank you SirWoogie for saving the day!
Main
Main Forum
PC Audio out, what's the best way to connect my receiver??
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: PC Audio out, what's the best way to connect my receiver?? (Read 1384 times)
squirrellydw
Trade Count:
0
Full Member
Offline
Last login:April 12, 2021, 11:30:22 am
on:
October 20, 2007, 11:51:01 am »
What is the best way to connect my PC to my receiver? I am guessing it would be digital out, then coax right?
Last Edit: October 20, 2007, 02:06:27 pm by squirrellydw
Logged
I b**ch. People listen!!
Green Giant
Trade Count:
0
Full Member
Offline
Last login:September 29, 2016, 06:50:57 pm
Re: PC Audio out, what's the best way to connect my receiver??
Reply #1 on:
October 20, 2007, 10:29:23 pm »
Yes, what kind of speakers you sticking in there?
Logged
Toxic Arcade, my first build
squirrellydw
Trade Count:
0
Full Member
Offline
Reply #2 on:
October 21, 2007, 10:45:49 am »
I will probably use these in the ceiling
http://www.amazon.com/Phoenix-Gold-6-5-inch-Ceiling-Speakers/dp/B0006FK3Y2
Logged
stevemartins
Trade Count:
0
Jr. Member
Offline
Last login:December 09, 2007, 11:59:05 pm
Reply #3 on:
October 22, 2007, 04:38:34 am »
I dont know about the best way, but the cheapest and easiest way is the way I'm running audio from my comptuer. Simply get a phono to rca adapter cable and just run your comptuer audio output to the rca inputs on your reciever. If you want a better solution you can get a soundcard with an optical audio output and run that to your reciever (assuming your reciever has an optical input) which would give you a cleaner audio signal, but i honestly do not think you will be able to tell any kind of difference in the sound quality in an arcade machine.
this is the cable I'm refering to
http://www.radioshack.com/sm-philips-3-5mm-stereo-to-2-rca-y-adapter-cable--pi-2453699.html
Logged
urbecrisch
Trade Count:
0
Full Member
Offline
Last login:March 30, 2025, 01:11:38 pm
I was the S**T back in '82
Reply #4 on:
October 22, 2007, 09:46:27 am »
Unfortunately I had problems with the Radioshack cable. If you don't want any buzzing sound/white noise I recommend this product. I have one connected between my PC speaker jack and my stereo receiver and the sound is perfect!
http://www.fxsound.com/mp3connector/index.php?vendor=0&subvendor=0&plus=0&refer=0
Logged
kelemvor
Trade Count:
0
Full Member
Offline
Last login:May 13, 2012, 09:40:44 am
Reply #5 on:
October 22, 2007, 10:00:24 am »
This really depends on what sort of outputs you have on your sound card.
Simplest way is jsut to use a headphone jack splitter that goes to the red/white RCA type plugs on the other end and then run that to the receiver. But if you're sound ccard supports 5.1, then you can get special cables to do that too and keep the surround sound signals.
Logged
genesim
Trade Count:
0
Full Member
Offline
Last login:April 12, 2010, 08:18:42 pm
Reply #6 on:
October 22, 2007, 11:33:43 pm »
You obviously need an aplifier to drive teh speakers.
After that just run a y-splitter from the front analog audio outs.
For multi speakers you can also go analog, or run the SPDIF through a number of ways.
Either use a computer 5.1 surround system which will decode for you, or run it to an amplifier with an on board decoder, but 5.1 really is overkill.
I use 4.1 and have great results by just having 2.1 to the front and 2.0 to the back using the analog outs. EAX is the bomb!
Logged
weasel-like_animal
Trade Count:
0
Full Member
Offline
Last login:March 12, 2023, 09:59:22 am
How appropriate, you fight like a cow.
Reply #7 on:
October 23, 2007, 11:36:08 am »
If you are set on using a receiver, digital out would get good results, then good speaker wire. If you don't need it though, might be more trouble then its worth. A high quality 2.1 system would be great, like the older Klipsch model is outstanding.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
