Author Topic: 4:3 lcd monitors over 20 inches?  (Read 8099 times)
Onward
  • Last login:October 23, 2007, 10:11:39 am
« on: October 19, 2007, 04:19:22 pm »
Do they excist?
I'm currently in the planning/research stages of a slim lcd upright, and I'm wondering if there's any lcd monitors larger than 20 inches? I can't seem to find any. I'm thinking a 24-25 inch 4:3 would be perfect, but it looks like I'll settle for a used 20 incher.
Oh, and hi all, I've been lurking for a couple of weeks, reading up on project threads and the wiki. Nice site!
Lars
Lars
csa3d
  • Will game for food
    • Galaxian Mame Conversion
Re: 4:3 lcd monitors over 20 inches?
« Reply #1 on: October 19, 2007, 04:36:03 pm »
there's a  few threads on this floating around this week.  Short answer, 20.1" is the largest I found.. I looked.
this one
Onward
« Reply #2 on: October 19, 2007, 06:32:19 pm »
I found this Samsung: http://www.pcmag.com/article2/0,1759,1409385,00.asp
But is is hella expensive and probably long out of production.
Lars
  • Last login:Yesterday at 10:30:50 am
« Reply #3 on: October 22, 2007, 11:37:00 am »
Wow those things are expensive.  I paid about $200 for a Dell 19" LCD monitor and I'm pretty happy with it - the bezel is quite slim and is even around the entire screen.
rooter
  • Last login:October 14, 2021, 01:31:15 pm
    • ShaunRoot.net
« Reply #4 on: October 22, 2007, 01:18:47 pm »
I was thinking about getting a 27" wide screen monitor myself.  I was thinking that the extra size would make up for the black bars on the sides of the display.  They are only about $350 as well.
http://3btech.net/welt27lcdtva.html
Am I missing something?  Is this a bad idea?
Did a little bit more reseach.  This TV is a little more, but the reviews for it are really good.
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16889022020&SortField=0&SummaryType=0&Pagesize=10&SelectedRating=-1&Page=2
« Last Edit: October 22, 2007, 01:28:46 pm by rooter »
csa3d
« Reply #5 on: October 22, 2007, 02:09:31 pm »
I thought I read somewhere on these forums that you get more playing area with a 4:3 vs 16:9, even with black bars.  I am guessing possibly this has to do with the measurements of the screens being diagonal?   :dunno
rooter
    • ShaunRoot.net
« Reply #6 on: October 22, 2007, 03:13:11 pm »
That is true for monitors of equal sizes, but I was suggesting getting a bigger one.  I threw together a comparison in Illustrator.  It looks like a 27" widescreen cut off with black bars has the same amount of real estate as a 22" 4:3 monitor.
A 26" 4:3 monitor would be awesome.  I'm going hunting right now.
rooter
    • ShaunRoot.net
« Reply #7 on: October 22, 2007, 03:14:53 pm »
please note that the 27" wide screen is the gray area, not the white.  I thought my post would have a white background, the blue background made it a little confusing.  This post should show it properly.
ahofle
    • Arcade Ambience Project
« Reply #8 on: October 22, 2007, 04:48:54 pm »
Newegg has about 10 or so 21"+ LCDs.  Most are for photography pros though and have poor response times between 16 and 20ms.
XyloSesame
  • Last login:September 17, 2024, 05:57:04 pm
  • the creepy prince guy...
    • The Nightingale Theater
« Reply #9 on: October 22, 2007, 04:56:16 pm »
You might want to check the Anandtech LCD Thread as a resource, specifically if you are concerned with response/contrast...
ahofle
« Reply #10 on: October 22, 2007, 06:05:22 pm »
Wow that's a great resource.  It's amazing how shady the LCD manufacturers are.
XyloSesame
« Reply #11 on: October 22, 2007, 10:58:31 pm »
Amazing how shady most all manufacturers are.
I did quite a bit of research prior to purchasing my first LCD, about 6 months ago, and was alarmed at how many units change parts and components within model releases; makes it a PITA to find what you're really wanting, esp when ordering online. Best advice is to take your time and exercise caution.
billpa
  • Last login:October 01, 2017, 11:25:31 pm
« Reply #12 on: October 23, 2007, 09:45:40 am »
So what LCD did you end up purchasing and what sort of setup are you using it in?
XyloSesame
« Reply #13 on: October 23, 2007, 10:53:23 am »
I've got a Dell 1905FP ready to put into a cab, once the cab is miraculously built by either myself or a band of merry elves. It's a poor quality, bottom of the line, mass marketed TN panel that plays the classics (my interest) with ease. The display even performs for some modern PC games, albeit not as well as other LCDs. I've tested the panel with the PC I intend to use, in both vertical and horizontal orientations, and it met my needs. It's neither a marathon winner, nor exceptional in any aspect. Nice and average (at best), and overall blah. However, the price couldn't be beat: mine was free.
All of my research was for my main PC at home. I've never cared for LCDs in the past because they're notorious for incorrect display of color and depth, and horrible for photo manip and design work. But I wanted to take the plunge when my CRT started to go. I ended up with an S-IPS panel NEC 20WMGX2 20" Widescreen to replace my trusty 21" Sony Trinitron CRT. Got a good price, but she was still more expensive than most of that size. However, I'm now a convert and advocate. She's a beaut.
For me, it comes down to use. A crappy TN LCD panel is fine for my use in a cab as I will be playing mostly classics and emus. I won't be using it as a DVD media box. I don't need pixel-precise 3D shading and rendering for F.E.A.R. Ghosting isn't much of an issue, and an average response time will be fine. So I can accept the compromise, get a lesser LCD, and either stay in budget or use that cash elsewhere on the cab.
genesim
  • Last login:April 12, 2010, 08:18:42 pm
« Reply #14 on: October 31, 2007, 06:00:48 am »
32 inches high equals 21 inches high.   To this day, I have some regrets with not going this route, but my whole arcade would need a rebuild, and I just don't have the energy....file it under GOOD ENOUGH!
rooter
    • ShaunRoot.net
« Reply #15 on: October 31, 2007, 09:45:21 am »
WHAT?
metahacker
  • Last login:January 17, 2024, 03:09:39 am
« Reply #16 on: October 31, 2007, 02:55:38 pm »
this is the biggest flat screen 4x3 ive seen
http://www.gotocol.com/cmp307xu.html
heh we have one of these at the office.  i was pretty particular about showing our work on a 1024x768 native 4:3 since it would show web page design 'comps' the most appropriately...
« Reply #17 on: October 31, 2007, 02:58:00 pm »
WHAT?
I think he means a 32" widescreen is 21" high.
XyloSesame
« Reply #18 on: October 31, 2007, 03:27:36 pm »
NICE. I've never seen this model... thanks for the link!
rooter
    • ShaunRoot.net
« Reply #19 on: October 31, 2007, 03:41:18 pm »
WHAT?
I guess that makes sense as long as you know that a 21" monitor is not 21 inches high.  Comparing a diagonal to a vertical doesn't make sense.  As I have shown earlier, a 27" widescreen monitor will have about the same real estate at 4:3 as a 22" standard monitor.
A 32" widescreen is MUCH larger than a 21" standard monitor, even with black bars on the side.
Hoopz
  • Intellivision Rocks!
« Reply #20 on: October 31, 2007, 03:48:34 pm »
Must be your first time reading genesim's posts....  :angel:
csa3d
« Reply #21 on: November 01, 2007, 07:50:43 am »
Wow.. I think I'm glad I didn't find that earlier.. resisting new temptations ;)
-csa
metahacker
« Reply #22 on: November 02, 2007, 01:14:14 am »
genesim
« Reply #23 on: November 02, 2007, 05:45:02 am »
What was confusing?   It is 21 inches(I believe I measured the screen the other day..but I could have just looked at the tag).   My point was that it was a couple of inches larger, with to me the added benefit of widscreen for other purposes.
For me, there is alot of advantage.
But yes, I do understand that 4:3 is not 16x9(or whatever it is).  Hence me designating widescreen.
Now lighten up.   I only gave an option for 21 inches(or thereof) with current tech.
Comparing a diagonal to a vertical does make sense if only considering the height.   In short, a 32 inch widescreen has everything that 4:3 ,21 display has and MORE!
A 27 inch widescreen is obviously shorter then the 21 inches(I think around 19 inches actually) so it doesn't fit your description.
genesim
« Reply #24 on: November 02, 2007, 10:07:16 am »
Hoopz,
I don't know where you got that random quote, but what is sad to me is how you would take the time to post that out of context.
From memore, I was referring to the fact that MAME is inaccurate as not being perfectly the original hardware...same goes for the multisynce monitor.
If you didn't understand, then you should have asked me instead of personal attacking.   I can't even make a simple post without that crap.   If that is all you got out of that thread I feel very sad for you.
