Author Topic: Monitor Issues  (Read 1448 times)
Andrew79
  • Last login:July 07, 2009, 12:07:38 pm
Monitor Issues
« on: October 16, 2007, 08:18:05 pm »
I have a Tekken Tag machine with a Wells Gardner monitor. The problem that I have run into recently is that the left half of the screen is darker than the right side. I haven't been able to figure out how to fix it. Is there anything I should be looking for inside the cabinet? Is this a indication that a Cap Kit is needed? If so, how much does this usually cost? Thanks
Ken Layton
  • Guru
  • Technician
Re: Monitor Issues
« Reply #1 on: October 17, 2007, 12:01:56 am »
Yes you need a capkit. The symptom you are describing is called uneven brightness. Capkits are cheap.
Andrew79
Re: Monitor Issues
« Reply #2 on: October 17, 2007, 11:34:51 am »
Thanks for the reply! I have never done a cap kit. Do you think someone with little experience in soldering and electronics could teach themselves through the tutorials online to do a capkit without killing themselves?  ;D Is there a good chance you could damage the monitor if you performed the capkit incorrectly? Or is it a fairly simple process once you do the difficult parts of discharging etc..
Also, someone else in another forum seemed to think since I recently moved the machine around in my garage and have been working on the marquee that it might be speaker interference or a degaussing problem. How do you degauss a monitor?
