Author Topic: Standard or Good Viewing Angles?  (Read 1184 times)
Jack Burton
« on: October 16, 2007, 12:28:56 pm »
I've decided to build my own cab finally, and I'm looking to make a very simple little sit down cabinet for playing fighting games.
I'm going to be using a 19" PC Data monitor.
From what I've seen on other peoples cabinets, a 45 degree inclination seems to work well.  Is there any particular reason you guys picked your specific viewing angle?
severdhed
  • Last login:Today at 06:17:39 pm
  • RIP Dinosaur Hippo
Re: Standard or Good Viewing Angles?
« Reply #1 on: October 16, 2007, 01:10:16 pm »
i mounted my monitor at an angle that runs parallel with the front of the marquee, and it works out great.
Chunce DeLeone
  • Last login:August 16, 2012, 02:58:11 pm
« Reply #2 on: October 16, 2007, 02:00:09 pm »
I tried a 45' angle for while and it was too much,  now I'm a little off 90', i may want to go a little more, the thing i found after staring at a 27 inch TV is that I like the monitor a little further back from the cp as not be overwhelmed by the screen
