Author Topic: I need help to finish off my cabinet.... software wise....VERTICAL CAB  (Read 3107 times)
nullb0y
  • Slow In Fast Out
    • WAT Racing
So my cab has been sitting in the corner entierly to long doing nothing
Basically,
its a vert cab and i cannot get any freeware monitor rotating software that will work
The computer is currently running win xp sp2 but i would rather run a front end without windows
oh my interface is also a minipac wired with usb
any help would make me happy
id like to see this thing work again
« Last Edit: October 15, 2007, 08:35:43 pm by nullb0y »
Slow In Fast Out
loadman
    • MaLa
Re: I need help to finish off my cabinet.... software wise....
« Reply #1 on: October 15, 2007, 07:43:07 pm »
Yeah I would not use rotation software.
FE's and Mame do a better job on their own.
There are many FE's that can run vertically:
Have a look at the Wiki:
http://wiki.arcadecontrols.com/wiki/Front-Ends
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #2 on: October 15, 2007, 07:45:27 pm »
wiki has everything... lol
any sugestions out of that list for win xp?
I want the menu to be vertical and mouse movement too...
im used to using mame32 plus
« Last Edit: October 15, 2007, 07:56:56 pm by nullb0y »
Slow In Fast Out
unclet
« Reply #3 on: October 15, 2007, 08:31:01 pm »
I use MALA myself ..... but I hear Atomic FE is also very good.
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #4 on: October 15, 2007, 08:35:21 pm »
right now im messing with the free version of fronty.... is that an okay program?
i might try a few and see what works
my major issue is i want it to be displayed in a vertical resolution as a menu.....
Slow In Fast Out
TOK
  • The Game Always Wins
Re: I need help to finish off my cabinet.... software wise....VERTICAL CAB
« Reply #5 on: October 15, 2007, 08:46:50 pm »
MaLa rotates the game menu vertical when you set the games that way.
loadman
    • MaLa
« Reply #6 on: October 15, 2007, 08:54:52 pm »
I use Command Line Mame. You could get into some issues if you want to use mame32 with a FE
This is my Vertical Cab running MaLa:
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #7 on: October 15, 2007, 09:07:08 pm »
okay it looks like mala is the one im going to try...
i cant seem to find an option to load in vertical where should i look?
Slow In Fast Out
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #8 on: October 15, 2007, 09:30:05 pm »
yeah i finally figured out how to flip the menu....
however my mouse still acts like its horizontal....
i guess i will rotate the mouse physically because this front end rocks ^_^
thanks EVERYONE
now to cut a bezel....
« Last Edit: October 15, 2007, 09:41:13 pm by nullb0y »
Slow In Fast Out
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #9 on: October 15, 2007, 09:58:33 pm »
okay i lied
now my games are all loading by default to horizontal and i have to manually change each one... is there a mame configuration file i should delite?
im using a normal mame.exe
Slow In Fast Out
loadman
    • MaLa
« Reply #10 on: October 15, 2007, 10:09:26 pm »
Nah, Just change options-controller-mouse   'Exchange axis'   ;)
okay i lied
An Easier way is to edit the section in mame.ini to:
### Mame CORE video options ###
norotate                0
ror                     1
rol                     0
autoror                 0
autorol                 0
flipx                   0
flipy                   0
or easier change options-mame config-options 'Rotate mame with mala'
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #11 on: October 15, 2007, 11:57:39 pm »
mala is pretty easy to use... ^_^
thanks for the help ^_^
Slow In Fast Out
loadman
    • MaLa
« Reply #12 on: October 16, 2007, 03:32:17 am »
Cool.
If you discover things feel free to add to the wiki using your forum username and password
Aurich
  • Last login:September 12, 2021, 01:34:32 am
« Reply #13 on: October 17, 2007, 04:26:29 pm »
I have a vertical cab. I use iRotate with an ArcadeVGA and it works great. Mala too.
loadman
    • MaLa
« Reply #14 on: October 17, 2007, 07:26:37 pm »
That is good to hear, maybe I shoud try that? .  When I set mine up I found that 95% things worked OK. Not quite good enough for me.
« Last Edit: October 17, 2007, 08:19:04 pm by loadman »
