Author Topic: What ancient Hantarex is this monitor ?  (Read 2419 times)
Level42
« on: October 10, 2007, 01:12:58 pm »
Does anybody recognize this Hantarex monitor ?
http://forum.arcadecontrols.com/index.php?topic=70069.msg742818#msg742818
There's heaps of plug-in modules, all Hantarex branded. The tube has a sticker Hantarex A51-211X.
Must be from around 1980.
grantspain
Re: What ancient Hantarex is this monitor ?
« Reply #1 on: October 10, 2007, 01:49:46 pm »
pretty sure thats a mtc90,i worked on a couple as a trainee back in the mid 80's
Level42
« Reply #2 on: October 11, 2007, 04:27:01 am »
Level42
« Reply #3 on: October 12, 2007, 05:27:14 pm »
So what do you think of it ? Worth giving it a try ? It has HEAPS and HEAPS of pots for almost everything....
grantspain
« Reply #4 on: October 12, 2007, 05:57:54 pm »
I remember those monitors,they suffered from very bad solder connections around the header cards  and i seriously doubt the flyback is still available
if it works then its worth getting if its really cheap,if its not working then don't touch
Level42
« Reply #5 on: October 13, 2007, 12:17:04 am »
I actually already have it since it's in the Puckman cab I bought last week :)
I kinda like the modular build-up. The CRT has been replaced in 1981 which meant the original didn't last very long ! (As this is a Puckman I figure the cab isn't really that much older). I'll see what it does, if it does anything. If it takes too much time, it'll be replaced by a TV :D
grantspain
« Reply #6 on: October 13, 2007, 02:09:21 am »
i am pretty those monitors had one hell of a charge left in the tube so be careful when you discharge the tube
Level42
« Reply #7 on: October 13, 2007, 02:20:07 pm »
Thanks for the heads-up, but if the seller is correct the cab stopped working a year ago....will be careful though :)
