Author Topic: MAME Machine and monitor question  (Read 1543 times)
wonkalow
  • Last login:February 11, 2010, 05:34:41 pm
« on: October 03, 2007, 03:41:22 pm »
First, im sorry I know theres threads on this (Ive read them in the past) but ive been away for a while and am finnally attempting to finish my first MAME machine, I just got a call about a nice condition cabinet and monitor for cheap, I have to call him back asap if I want it or not, so hopefully I can find an answer quicker (im still searching for those threads just incase)
it's got I believe he said a "low resolution" monitor. I want my machine to play everything from atari up to as much mame as I can get, in good quality, will this one work for what I need? or do different reso monitors look different?
northerngames
  • Trade Count: (+18)
Re: MAME Machine and monitor question
« Reply #1 on: October 03, 2007, 06:11:41 pm »
call him asap for the monitor make and model.
bluevolume
  • Last login:July 22, 2019, 12:14:32 pm
  • I wish I'd bought more pins...
« Reply #2 on: October 04, 2007, 12:03:50 am »
He probably means "standard resolution", which is 320x240.  Most MAME games will work on a standard monitor natively, though you will need to tweak the settings to get each game to show correctly.  For the games that require a higher resolution, you can use hardware stretching to make due.  You will also need to do that for games with opposite orientation (monitor mounted horizontal, game designed for vertical).
If you do go with an arcade monitor, you're going to want an ArcadeVGA board from Ultimarc (or buy it directly from Divemaster if in the US).
Figure out what the make, model, and size of the monitor are.  Also, if you can have the guy power it up and see what the picture looks like, this is pretty important.  (Unless you are comfortable with rebuilding a monitor chasis).
SABRECADE LIVES ON
