Author Topic: Flat top LED  (Read 1302 times)
Dudeman
  • Last login:April 23, 2025, 06:42:24 pm
  • Ecky ecky ecky ecky P'Tang! Zoop-boing mmmzoesm...
Flat top LED
« on: September 25, 2007, 09:50:53 am »
Simple question:
I know you can buy flat top LEDs, but they are not real common. Is it possible to just sand down the top of a normal LED flat without affecting its operation?
Dmod
  • Last login:July 12, 2012, 06:50:45 pm
Re: Flat top LED
« Reply #1 on: September 25, 2007, 10:18:31 am »
I'm not a leading expert on LED's but here's my 2 cents:
The light generating part of the LED is a diode that's buried in the bottom of the package.  The curved package is a plastic lens designed to channel and spread the light.  Altering it's shape would affect the beam pattern and light output.
As long as you don't sand down to the diode, the LED will continue to function but you're likely to reduce the light inensity.
edit::  I guess I should have added that flat LED's are readily available from electronic parts distributors.  Try Digi-Key (www.digikey.com).  Here's a link to their catalog.  The diode models in Figures 1,2, and 3 are all flat-top.
« Last Edit: September 25, 2007, 10:31:47 am by Dmod »
My Projects:
Suspended Animation Scratch-built Cab
Driveshaft Arcade Seat Platform
Dudeman
Re: Flat top LED
« Reply #2 on: September 25, 2007, 10:32:09 am »
That's what I was thinking.
waveryder
  • Last login:July 14, 2011, 04:26:17 am
  • I Troop, therefore I am
    • BubbleGum Custom Art
Re: Flat top LED
« Reply #3 on: September 25, 2007, 12:54:59 pm »
I get mine off ebay very cheap! The place is called "amigos of china" very quick delivery. Ive tried sanding down standard LED's but wasnt happy with the results. The flat tops look more like someone has literally cut the rounded tip off.
« Last Edit: September 25, 2007, 12:56:51 pm by waveryder »
When pixelated clipart just wont do, just call for Betty
mr.Curmudgeon
  • It's going to hurt your brain. A lot.
  • Last login:October 11, 2021, 07:15:49 pm
  • Huzzah!
Re: Flat top LED
« Reply #4 on: September 25, 2007, 02:09:17 pm »
"amigos of china"
 :dizzy:  Interesting name.
