Author Topic: help installing dragon king  (Read 1953 times)
corrupt27
  • Last login:December 17, 2021, 09:46:35 am
« on: September 22, 2007, 07:34:47 pm »
Hello everyone,
  I have been having a hard time setting up dragon king.  I have used mame32 but never a frontend with the regular mame.
  I started by downloading mame0119b.exe and dragonking .99. I installed mame into C:\mame and changed nothing other than adding a few roms to the C:\mame\roms file. (zipped) I then installed dragonking to the C:\dragonking folder.
  I went throught the dragon king master install settings.
1st the mame.cfg changed the path to path=c:\mame\   (no other changes)
2nd catvers i downloaded and extracted the files to c:\dragonking\list generator\CatVers\catvers.ini
3rd changed the dir.ini  roms=c:\mame\roms\  and Primary Artwork Dir=c:\mame\artwork (there is no artwork)(not sure where to get the artwork and how to set that up)
4th i run the generate list and receive the error RUN TIME ERROR "62" INPUT PAST END OF FILE  :angry: :angry:
So i changed the mame.cfg path=c:\mame\mame   :applaud:
but the master list is empty. What am i doing wrong please help  :hissy:
Cakemeister
  • Last login:May 31, 2024, 06:23:16 pm
Re: help installing dragon king
« Reply #1 on: September 22, 2007, 07:56:14 pm »
You might try running an earlier version of MAME. Also, make sure you can run MAME from a command line, ie.
cd \mame
mame gridlee
Just run the dumba installation program and you should be able to get it to work. Keep in mind, however, you'll need to make sure your path names entered into the .ini file match what DK expects, which IIRC end in a backslash, ie. your rom path should be c:\mame\roms\ I could be wrong on the path thing, I'll check my own installation.
Post back if you can't get it to work.
Old, but not obsolete.
corrupt27
« Reply #2 on: September 22, 2007, 08:44:36 pm »
I ran the dumba to no avail. Could it be that i have no artwork?
  • Last login:Yesterday at 10:07:01 pm
« Reply #3 on: September 22, 2007, 09:10:19 pm »
Well it's more like that isn't an artwork directory.  You are confusing mame artwork (bezels, ect...) wth fe artwork (snaps flyers, ect)
you need to point that to "c:\mame\"
and mame needs to have the folders:
snap
titles
flyers
cabinets
marquees
And although I can't confirm this (the version on there is oooooooold) it wouldn't hurt to have at least one png file in each folder.
corrupt27
« Reply #4 on: September 22, 2007, 09:15:52 pm »
tryed. Created the requested folders and added an ge in each. Still nothing. I run the generate the list and nothing is listed.
corrupt27
« Reply #5 on: September 22, 2007, 09:17:32 pm »
You stated that the software is old. Where can i get a newer version?
« Reply #6 on: September 22, 2007, 09:31:10 pm »
you can't  it isn't ready yet :)
Cakemeister
« Reply #7 on: September 25, 2007, 09:03:19 am »
Your dirs.ini should look something like:
[Dirs]
***Enter all your rom paths... Just like you do in a mame.ini
roms=C:\mame\roms\
***Put These in as a base folder.  I.E. If your snaps are in "e:\mame\snap\"
***then the entry should be: "e:\mame\"
Primary Artwork Dir=C:\mame\
Additional AW Dirs="\artwork\" "\cabinets\" "\cpanels\" "\movies\" "\snap\"
But I don't think you need the artwork dir set up in order to generate a list.
corrupt27
« Reply #8 on: October 01, 2007, 11:09:19 pm »
Still no good. Oh well off to a different front end. Thanks for all the help. The menu looks good. I just dont know why it wont generate the list. :dizzy:
Going to try ATOMICFE. Mamewah works. If i figure out what i did wrong ill let you guys know. Thanks
