Author Topic: MAME - How to Reset Settings?  (Read 30870 times)
FrizzleFried
    • Idaho Garagecade
« on: September 21, 2007, 07:26:46 pm »
I managed to screw the pooch and map my P1 button as both UI SELECT and UI EXIT.  Now every time I go in to try to change stuff it just exits as I can't select.
Anyone know what file to delete/change/etc to reset settings back to MAME default?
KDOG
  • Last login:September 18, 2020, 03:08:26 pm
Re: MAME - How to Reset Settings?
« Reply #1 on: September 21, 2007, 07:35:36 pm »
Have you tried replacing the exe file.
KDOG
« Reply #2 on: September 21, 2007, 07:37:01 pm »
Or mame ini file?
FrizzleFried
    • Idaho Garagecade
« Reply #3 on: September 21, 2007, 07:45:58 pm »
Is it a matter of just replacing the EXE file?    The .INI file doesn't have any of the options saved in it from what I can see.   The exe I am using is a custom compiled one... I hope I have it around somewhere.  I ASSUMED there was an external file that held all the UI settings, etc...
FrizzleFried
    • Idaho Garagecade
« Reply #4 on: September 21, 2007, 07:57:52 pm »
Nope...replacing the EXE doesn't do squat...grrr...
FrizzleFried
    • Idaho Garagecade
« Reply #5 on: September 21, 2007, 08:14:35 pm »
For those interested...
The answer is "DEFAULT.CFG" in the "CFG" directory.  Alternatively you can go in and edit the one offending key map...which I did.
