Author Topic: xarcade blank control panel can it use the sanwa buttons or just happs?  (Read 1510 times)
robot8319
  • Trade Count: (-2)
  • Last login:August 25, 2009, 11:22:02 pm
i am seriously considering buying an xarcade blank control panel an popping a keywiz and sanwa parts into it..
will the sanwa buttons work or just the joysticks?
i prefer to use the sanwa's because of the green apple color look of the buttons.
i know someone has bought the xarcade blank panel if you did..were you able to use the sanwa parts?
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
Re: xarcade blank control panel can it use the sanwa buttons or just happs?
« Reply #1 on: September 19, 2007, 11:08:29 pm »
Th x-arcade  button holes are 1-1/8" and Sanwa buttons are a little bigger
It wont work
There are other buttons from other manufacturers though.
robot8319
  • Trade Count: (-2)
« Reply #2 on: September 20, 2007, 12:03:06 am »
so are you just saying i can use happs only then right? either way thats cool.
i bought it for happs but i wanted to try some sanwa's atleast once.
Goz
  • KOTA
« Reply #3 on: September 20, 2007, 01:20:07 am »
The Sanwa buttons are just a little bigger. You should be able to enlarge the holes enough to fit the sanwas but not so big that the Happs dont work.
Happs are 1 1/8"
Sanwas are 30mm
30 mm = 1.18110 in
