Author Topic: Finger guard for 200mm fan?  (Read 1375 times)
Avrus
  • Last login:September 07, 2011, 09:17:25 pm
  • Canada
    • The Avrus Arcade Project 'Conquest'
« on: September 17, 2007, 03:03:04 pm »
Anyone have a suggestion of where to find or even how one would make a finger guard for a 200mm fan?  I could leave it without the finger guard but it's just going to look unpolished to have a 3/4" gap from the outside to the fan.
Found some 180's or 254's I guess I could just use the 254's ...
« Last Edit: September 17, 2007, 03:11:23 pm by Avrus »
______________________________
'Conquest' upright 4 player arcade project log:
http://avrus.blogspot.com/
SavannahLion
Re: Finger guard for 200mm fan?
« Reply #1 on: September 17, 2007, 03:17:30 pm »
Depends on how fancy you want to get. At 200mm, I would go with a mesh like this example. They're reasonably priced for the sheets that need to be formed. I forget what that specific perforated metal is called though.
BobA
  • What Me Worry?
« Reply #2 on: September 17, 2007, 03:27:03 pm »
Was going to say your size is a bit hard to match so you probably need to fabricate your own from metal mesh available at case moding places.  The honeycomb mesh is the best for airflow. http://www.mnpctech.com/moddersmesh.html
Ken Layton
  • Guru
  • Technician
« Reply #3 on: September 17, 2007, 07:16:32 pm »
Just go to the hardware store and get a small piece of "hardware cloth". It comes in different sizes of the squares and you cut it with tip snips.
