Author Topic: Help with bezzle  (Read 2417 times)
gamecaptor
  • Last login:October 15, 2004, 01:26:48 pm
Help with bezzle
« on: April 30, 2003, 01:30:07 pm »
Here is my problem. I'm converting an old arcade cabinet into a MAME cabinet. There was a 25" monitor in there and I replaced it with a 27" Wells Gardner D9200 monitor. Now the bezzle doesn't properly cover the monitor (i.e. it cuts off part of the screen). The outer dimensions of the bezzle are 25" x 25". Can I purchase a new bezzle that will fit this or will I need to have a new one made?
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
Re:Help with bezzle
« Reply #1 on: April 30, 2003, 01:42:27 pm »
I believe Happs Controls carries 27" bezels. Some people also make their own.
http://www.happcontrols.com/monitors/49010500.htm
gamecaptor
Re:Help with bezzle
« Reply #2 on: April 30, 2003, 01:43:52 pm »
Sorry, that should have read "bezel" :)
Cool, I'll check them out, thanks CitznFish.
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
Re:Help with bezzle
« Reply #3 on: April 30, 2003, 02:08:39 pm »
Heh i thought you were going for that lastest - 'zzle' craze of talking :
hizzle, shizzle, bezzle, etc  ;D
Birdtales
  • Last login:October 06, 2020, 10:00:31 am
  • You won't like me when I'm angry.
    • Birdtales
Re:Help with bezzle
« Reply #4 on: April 30, 2003, 02:15:09 pm »
Here's one on eBay, it was a Buy It Now for 15.00 but someone bid on it.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3221454155&category=13718
Coming Soon
foosguy27
  • Last login:February 05, 2004, 10:20:45 pm
Re:Help with bezzle
« Reply #5 on: May 01, 2003, 10:44:42 pm »
Here's what I did and it worked awesome.  I bought a piece of lexan and had it cut to the size of the old glass bezzle and set it in place.  I taped off where the monitor goes, and then flipped the lexan over.  I taped off the square where the monitor would go and used black spray paint to make the bezzle.  You have to put on 3 or 4 light coats but it worked awesome.  Looked like I bought it right from the factory.  And no matter how mad I get, there is no way I am going to be able to brake that piece of lexan.
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
Re:Help with bezzle
« Reply #6 on: May 01, 2003, 11:30:35 pm »
Oi! This is just plain painful!
Is it just me or has spelling taken a dive lately?
I can't read these things without cringing!
Spelling counts, people!!
If you build a frankenpanel, chances are I don't care for you as a person.
  • Last login:February 01, 2026, 01:32:52 pm
Re:Help with bezzle
« Reply #7 on: May 02, 2003, 12:44:33 am »
No it doesn't.  :P
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
Re:Help with bezzle
« Reply #8 on: May 02, 2003, 01:11:32 am »
I did this with my 1st attempt- used plexi though. Taped off the screen part with painters masking tape to avoid any bleed thru, and sprayed the backside a few coats of red, to match the red t-molding. It comes out real glossy and shiny once you flip it right side out.
I used a black Sharpie on the backside of the glass before painting and drew a circle where the monitor power button was, as well as a sketched "stencil" of Homer. Once the red was on it, it was sealed in and looked great. Behind the circle in front of the power button(huh?) I glued a small rubber foot like youd find on the bottom of a PC or appliance so you just needed to push the circle to power the monitor
Mind you this was when I was first using a PC monitor and hadn't yet wired an all-in-one power switch
I've switched to tinted plexi now that Im using a TV, and *LOVE* it- with the power off it's all black and when playing, all you see is the screen
