Author Topic: Getting glue off of cabinet?  (Read 1359 times)
bluevolume
  • Last login:July 22, 2019, 12:14:32 pm
  • I wish I'd bought more pins...
« on: September 08, 2007, 12:21:53 pm »
I've spent the morning removing the vinyl decals from the sides of my cabinet (heat gun), but now I'm "stuck" with the leftover glue.  I've tried a few things to remove it (goo gone, goof off 2) but it doesn't seem to be working.  I also tried just sanding it with an orbital and 60grit, that is just making a bigger mess.
SABRECADE LIVES ON
csa3d
  • Will game for food
    • Galaxian Mame Conversion
Re: Getting glue off of cabinet?
« Reply #1 on: September 08, 2007, 01:43:31 pm »
i think i used 120 grit, but yeah.. same technique.  Sand away.  If you dip to low, time to get out the Bondo.  Prepping the cab was highly time consuming.
-csa
Cakemeister
  • Last login:May 31, 2024, 06:23:16 pm
« Reply #2 on: September 08, 2007, 02:44:39 pm »
What I did was put on goo gone, let it soak for a while, then scraped with a large plastic spatula used for painting and drywall. A plastic kitchen spatula would probably work just as well.
Apply plenty of elbow grease. :)
Once most of the gunk was gone I used a sander. That got the rest of it.
Old, but not obsolete.
MrMojoZ
  • Last login:June 25, 2009, 11:34:56 pm
« Reply #3 on: September 08, 2007, 02:49:06 pm »
Ugh this is the step I am on, glad to hear it is a quick and easy process.  :-\
bluevolume
« Reply #4 on: September 08, 2007, 05:35:04 pm »
I hit Home Depot, and found this stuff called Adhesive Remover (red tin can).  I used a paint brush to paste it on to the side of the cab, then waited about 15 minutes.  The glue scraped off very easily with a metal putty knife, then I sanded it with an orbital.  One side is done and it looks great.
Be careful you don't get that stuff on your skin.  It BURNS like acid!
SABRECADE LIVES ON
MrMojoZ
« Reply #5 on: September 09, 2007, 01:09:17 am »
I will try that, thanks.
