Author Topic: Help with mame machine too :D (Arcade VGA stuff)  (Read 1545 times)
Jetto Funk
  • Last login:April 09, 2013, 03:10:28 pm
  • Moo
« on: September 06, 2007, 04:18:54 pm »
I picked up an arcade machine that already had the work done. The guy said it worked prior to me picking it up. It has an arcadevga (old one) running into a JPac and optipac. Pretty good deal for 75 bucks. So anyways I decided to toy with it today and couldn't get the damn thing to work. I managed to get the pc running visually with a computer monitor and an old voodoo graphics card but I can't get anything to work with the arcadevga. Only thing I have is a blank screen with whatever color I enhance the most. any ideas?
2600
Re: Help with mame machine too :D (Arcade VGA stuff)
« Reply #1 on: September 06, 2007, 04:45:55 pm »
IIRC, The original AVGA requires an Arcade Monitor.  Have you tried plugging it into an Arcade Monitor?
Jetto Funk
  • Moo
« Reply #2 on: September 06, 2007, 06:16:35 pm »
Yes, thats what its on right now, I used my PC monitor to see if it would work (doesnt)
When I used the voodoo card I was able to get a visual on my pc monitor
Kevin Mullins
    • Me on Myspace
« Reply #3 on: September 06, 2007, 06:46:03 pm »
Do you have all the proper drivers for the ArcadeVGA?
And UNinstall all other graphics hardware and drivers first.
genesim
  • Last login:April 12, 2010, 08:18:42 pm
« Reply #4 on: September 06, 2007, 08:49:45 pm »
Are you using the proper output?
The VGA standard is for arcade monitors.  You need a converter for the DVI to vga.
2600
« Reply #5 on: September 06, 2007, 09:11:27 pm »
The original didn't have a DVI connector.
Although, if you are using the 7000 series version then you do have to use the bottom connector I believe.  Email Andy at Ultimarc about it.  He's taken all the information about it off his website and I may not be remembering correctly.
Jetto Funk
  • Moo
« Reply #6 on: September 07, 2007, 10:15:55 am »
This is the card that I have
2600
« Reply #7 on: September 07, 2007, 11:13:53 am »
Yeah, that's 7000 series.  IIRC, you have to use the bottom connector(blue) first.
