Author Topic: Hiding pointer/cursor or changing starting position Windows XP  (Read 2260 times)
Pitou
  • Last login:July 01, 2025, 12:33:17 pm
« on: September 06, 2007, 02:12:33 pm »
Hello,
I did the best to hide the cursor on startup. (yes even using the .Default registry, it still show for 1 sec)
Now my idea would be to force windows to put the cursor in the bottom right corner.
Anyone knows how to do this?
Thanks.
Pitou!
Justin Z
  • Last login:August 23, 2024, 07:17:22 am
Re: Hiding pointer/cursor or changing starting position Windows XP
« Reply #1 on: September 06, 2007, 03:37:52 pm »
Another solution I've seen is installing a pointer set that has the pointer as a one-pixel sized black dot.  I have not done this myself, but I'm sure you could find information with a search.
Pitou
« Reply #2 on: October 04, 2007, 10:46:24 am »
bump
jaquer
  • Last login:January 13, 2025, 10:20:49 pm
  • Geek of no Qualifications
It's pronounced hacker.
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
« Reply #4 on: October 05, 2007, 10:03:46 am »
See if this helps: http://jaquer.izaram.net/files/Mousehide.zip
So people have a better idea of what they would be downloading, here is a description from the readme..
Mousehide by Izaram
Mousehide is a very simple VB proggie that will hide your mouse pointer after
approximately 1 second of inactivity. Simply run it and leave your mouse
untouched and your pointer will simply disappear.
I'm still working on a way to hide the "cute" little window (minimize to tray
maybe?). For now, you can run it like this "mousehide /hide" and you won't see the window appear at all, but be careful, there's no way to stop the program this way other than Ctrl-Alt-Del and end its task.
Send any feedback, good and bad, to domoper@izaram.net
« Last Edit: October 05, 2007, 10:47:55 am by Organic Jerk »
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
BobbyG66
  • Last login:November 13, 2016, 11:52:09 am
  • Current project: Dodgeball
« Reply #5 on: October 05, 2007, 03:52:52 pm »
I have a "one-pixel sized black dot." on my screen and it's burning a hole in my brain!
Sorry, it's Friday... I'm burned. :timebomb:
Half of the people you meet are below average.
metahacker
  • Last login:January 17, 2024, 03:09:39 am
« Reply #6 on: October 09, 2007, 04:04:56 pm »
i think you need the NULL.ICO or something similar to set your pointer in the mouse properties of the control panel.
Touch screen driver sets usually include a set of mouse cursors that have a nulled out pointer.
I think you should be able to dig them out from here or somewhere similar
http://www.elotouch.com/Support/Downloads/dnld.asp#windows_universal
http://solutions.3m.com/wps/portal/3M/en_US/3MTouchSystems/TS/TechnicalInformation/TouchDrivers/
I know that when we've developed custom touch screen kiosks at work both of those guys (ELO & 3M) have supplied an 'invisible cursor' pointer icon with the standard driver pkg.
