Author Topic: Need help please!  (Read 1450 times)
SonicSlammaster
  • Last login:December 29, 2009, 07:00:14 am
Need help please!
« on: September 05, 2007, 04:09:31 pm »
Hey folks i need some help with a problem ive just run into reguarding my pc monitor, hopfully some1 here can help me.
I was messing about with a sega genesis emulator a few minutes ago and was doing a bit of playing around with the resolution then all of a sudden my pc monitor changed color its now green... the disply through my tv set is fine though... I dont know how to fix this any help would be much appresiated guys
thanks in advance :)
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
Re: Need help please!
« Reply #1 on: September 05, 2007, 04:13:13 pm »
Do not know anything about "Sega Genesis emulator" but if it has a setting related to sync on green, check that.
Rick Nieman
Rick@niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
SonicSlammaster
« Reply #2 on: September 05, 2007, 04:59:58 pm »
Unfortunatley there is no sync to green option on the gens emulator..i think it might be my actual monitor though because i tryed switching to the onboard display as apposed to using my graphics card and the monitor is still the same. It may be my vga cable or my monitor is messed up now... Thanks for the reply though cheers mate :)
siastbill1
  • Last login:February 14, 2023, 08:14:53 pm
« Reply #3 on: September 06, 2007, 02:04:28 am »
This can happen if the cable is loose (as all the pins don't connect), but since you've tried this with a different video card that's probably not it. The cable could be bad, but it is odd for that to happen out of nowhere.
It may be that the monitor was going bad, and the emulator just gave it that little push over the top?
But, sometimes weird magnetic fields can throw things off (unshielded speakers for example), which will also give you that green colour. Try to degauss the monitor, and also look for a reset button. Lastly, it never hurts to sit things unplugged for a few hours, just to let them discharge. Just a shot in the dark :)
/bill
SonicSlammaster
« Reply #4 on: September 06, 2007, 06:38:32 am »
I have tryed leaving the monitor off for a good 12hrs but unfortunatley no change.. I will have to try and degauss the monitor im 100% sure its not the vga cable now. Your right though i beleive the emulator gave it that last pushoff, its not egsactly a new monitor i got it in 03 but i did expect it to last at least 6 years :( thanks for the help :)
eccs19
  • Last login:April 20, 2021, 10:36:08 am
  • Just plugin away!
« Reply #5 on: September 07, 2007, 03:39:49 pm »
Do you have another monitor you can hook up?  This will at least tell you if it is the monitor or not.
Working - Mr. Do! - Neo Geo 4 Slot - Bartop Mame
Project(s) - Pacman
SonicSlammaster
« Reply #6 on: September 08, 2007, 08:45:11 am »
I do have an old compaq monitor somewhere around but im not sure if those monitors are compatible with a standard pc. Ill have to wait till monday untill i can test a new monitor on it hopefully its a minor problem i dont want to have to buy a degaussing wand or open this thing up either..  Ive had a bad week with this stuff just yesterday a feckin cd exploded in my dvd cd-r drive messed the thing up this is goin to set me back a few more bucks and set my project back a week or two..:(
