Author Topic: CPS3 Emulator v1.0a/Mamewah help (It's been a while)  (Read 5555 times)
postalp123
  • Last login:March 18, 2024, 09:07:50 pm
  • Retro-gamers don't just play, they reminisce.
« on: September 05, 2007, 12:32:32 pm »
Hey mates, long time no see.
Now that I finally have a new CPS3 platform to intergrate into my Cab (Mamewah based) Im wondering how to intergrate the new nebula-based CPS3 Emulator v1.0a (Found here: http://nebula.emulatronia.com/) so that it starts up properly from MAMEWAH v.92.
At this moment after playing with all the Send Rom Paths, etc... nothing seems to get it started, here's my cfg:
;LIST GENERATION SETTINGS
ROM Path = C:\EMULATION\CPS3\ROMS
ROM Extension = ZIP
List Generation Method = 0
;EXECUTION SETTINGS
Emulator Executable = C:\Emulation\CPS3\emulator.exe
Send ROM Path = True
Send ROM Extension = False
Use Long Filenames = True
Use Quotes around ROM Filenames = False
Show DOS Box = 2
Default Options =
Extra Options #1 =
Extra Options #2 =
Controls.dat Viewer Filename =
Controls.dat Viewer Default Options =
Launch Controls.dat Viewer before Game = True
IPC Filename / Path =
Running on XP
Any suggestions??
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
Re: CPS3 Emulator v1.0a/Mamewah help (It's been a while)
« Reply #1 on: September 05, 2007, 01:42:35 pm »
Don't really have an answer, but a question.  Why not just use the latest mame as it also has full cps3 support?
postalp123
« Reply #2 on: September 05, 2007, 01:46:01 pm »
Cause im running my cab on a 1.4GHz, gotta squeeze every last bit of juice out of it.  ;D
CthulhuLuke
  • Last login:May 22, 2025, 01:03:42 am
  • old school
    • CthulhuLuke's Arcade Parodius
« Reply #3 on: May 01, 2008, 01:40:19 pm »
This topic has been dead for a while, but I thought I'd say something because I just got my Mamewah working with CPS-3 1.0a by the Nebula creator. (Also, hello everyone again, I haven't posted on here in years :D )
For my cfg, I came up with the following ini :
ROM Extension = ZIP
;EXECUTION SETTINGS
Emulator Executable = C:\Emulation\CPS3\emulator.exe [name]
Show DOS Box = 2
Default Options =
Extra Options #1 =
Extra Options #2 =
Then in your emulator.ini for your CPS-3 emulator, make sure you have Autofull = 1 enabled. You will probably have to map a key to Alt+F4 to exit the program easily, but this is the best method I've come up with. The only reason why I don't like using Mame for CPS-3, is I haven't been able to find the proper no-chd files yet, and CHD cps-3 loading takes like 20 minutes a game :(
- hope this helps anyone else curious about this issue.
Jdurg
« Reply #4 on: May 01, 2008, 03:44:56 pm »
That ONLY happens the first time you run the game and it's the game loading the data from the "CD" to the "RAM" on the board.  Once it's loaded once, it is saved in the nvram of the game.  So if you are willing to just put up with the load times once (Hint:  unthrottle MAME while it's loading to get a very slight speed increase) you won't have to deal with it again unless you lose your nvram file.  Or, you could just get an nvram file and put it in the proper folder and never have to deal with it.  Once the nvram is there, it loads up might fast.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
