Author Topic: using ultraISO to create bootable mame on dvd.  (Read 1325 times)
esaelectrionics
  • Last login:December 11, 2013, 01:05:50 pm
« on: August 31, 2007, 07:30:14 am »
Has anyone used this program to create a bootable mame system on dvd/cd?,
its a bit like magic iso but seems to work a bit better for editing ISOs and making
programs boot from cd/dvd.
I was thinking of cutting a slot in my cab and then mounting a dvd drive instead of using a hard drive, just swapping the disks for different applications or versions of mame, not tried it yet but hopefully it would work without needing to write to a harddrive.
i have a basic version of windows98 that runs on cd, so im pretty sure dos mame would work pretty well.loading from a fast cd drive seems nearly as quick as the harddrive.
« Last Edit: September 02, 2007, 06:09:15 am by esaelectrionics »
Kangum
  • Last login:February 25, 2018, 07:46:20 am
Re: using ultraISO to create bootable mame on dvd.
« Reply #1 on: September 02, 2007, 09:36:03 am »
im not sure wich romset you are using but ver 108 of mame takes up like 15 gigs. just by itself. even if you used a dvd thats 3 or 4 swaps just to show the full set. if you have other imulators then add a few more.
i have not used ulltraiso but i have run mame off a cd before and there is most definatly a lag between switching games as well vs using a hard drive.
booting mame off a cd imho is only good for getting a friend addicted to emulation not so useful for a cab.
