Author Topic: 3 sided cocktail cab - Atomic FE question  (Read 1073 times)
joewhite73
  • Last login:July 08, 2015, 04:16:20 pm
« on: August 30, 2007, 06:26:11 pm »
Is there a way to make Atomic FE rotate only 90 degree at a time (for a 3 sided cab)
Havok
  • Trade Count: (+17)
Re: 3 sided cocktail cab - Atomic FE question
« Reply #1 on: August 30, 2007, 06:39:55 pm »
Sure - you set the middle side to horizontal, and the other two sides vertical left and vertical right. This is done via AtomicManager, under the General tab, screen orientation:
