Author Topic: 2 U360 joysticks - MaLa only sees 1  (Read 4932 times)
ARTIFACT
« on: August 30, 2007, 12:52:36 am »
In the joystick options, only 1 joystick shows up in the test/check tab (where you can SEE the joysticks and test)... J2 is grayed out.
oh, and this results in not being able to scroll my lists (< and >) and letter scroll (up and down).
How can I make MaLa SEE BOTH sticks?
Thank you very much.
loadman
    • MaLa
Re: 2 U360 joysticks - MaLa only sees 1
« Reply #1 on: August 30, 2007, 01:11:56 am »
ARTIFACT
« Reply #2 on: August 30, 2007, 02:06:08 am »
aaaahhhh
you know what... i saw this thread and I scrolled thru missing the info part (I thought i twas about missing IDs there)
Got it! thanks.
I switched to using MALA TREE instead anyway..
Trackball to scroll up/down
P1 Start = Select
Exit (dedicated on my cab) = exit tree selection (go to parent)
I guess I can still use J2 up/down to quickly scroll letters
THANKS! :)
loadman
    • MaLa
« Reply #3 on: August 30, 2007, 06:10:30 am »
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
« Reply #4 on: August 30, 2007, 12:14:07 pm »
THANKS! :)
That's exactly what I do with my 2nd stick, use it to skip the abc....  And on stick 1, moving left and right goes page up and down.  With this config, I can get to any game super fast.
ARTIFACT
« Reply #5 on: August 30, 2007, 12:32:19 pm »
i loooooove scrolling games with the 3'' happ translucent blue trackball!!!!
its so sooth and you can 'throw' the ball super fast and let it spin, then STOP it instantly on a game :)
it makes a world of difference compared to 'holding' a joystick... less tiring.
