Author Topic: frontends  (Read 2866 times)
killerkilley
  • Last login:August 24, 2007, 06:38:08 pm
frontends
« on: August 20, 2007, 03:51:18 pm »
is their a front end i can start from windows go straight into my arcade monitor through my VGA graphics card and just play games easily until i can set it up properly thanks
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: frontends
« Reply #1 on: August 20, 2007, 05:29:18 pm »
What?
Green Giant
Re: frontends
« Reply #2 on: August 20, 2007, 05:30:53 pm »
Yes
Toxic Arcade, my first build
loadman
    • MaLa
Re: frontends
« Reply #3 on: August 20, 2007, 07:19:20 pm »
Maybe it would make more sense in German?
ihr ist ein vorderes Ende, das ich von den Fenstern beginnen kann einsteige gerade in meinen Arcademonitor durch meine VGA Graphikkarte und gerechten Spielspiele leicht, bis ich sie aufstellen kann richtig Dank
 :laugh2:
Dude....  Please rephrase the question  ;)
« Last Edit: August 20, 2007, 07:21:25 pm by loadman »
(+_+)
  • Let me splain.
  • Last login:July 27, 2012, 09:00:32 pm
  • For I am ]{eyser Soze
Re: frontends
« Reply #4 on: August 20, 2007, 09:33:16 pm »
I was looking at Maximus Arcade the other day and thought it was a nice, well polished front end. Mala and Minwah are also very nice.
This plan is so perfect, it's retarded. -- Peter Family Guy
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
Re: frontends
« Reply #5 on: August 20, 2007, 10:56:29 pm »
Five posts so far and not one of them with any trace of punctuation. I'm going to be kind and assume that you're disabled and have trouble using a keyboard. The alternative is too horrible to think about.
killerkilley
Re: frontends
« Reply #6 on: August 21, 2007, 03:46:10 pm »
well sorry i am dyslexic and can't help it. Just run away with it sometimes. I am sorry if it means that much to you i just wanted a bit of help.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: frontends
« Reply #7 on: August 21, 2007, 03:56:36 pm »
What do you have set up so far ? (e.g. can you boot to Windows on your arcade monitor ?)
Letting us know what you have working is important, then we can better help you.
Also, make sure that you check the Front Ends page in the wiki.
On my first MAME cab, I used MAME32 until I got MAMEWah properly configured. Since then I have used MaLa exclusively.
Working: Not Enough
Projects: Too Many
Progress: None
killerkilley
Re: frontends
« Reply #8 on: August 21, 2007, 04:34:26 pm »
i am just getting a flickery screen. i have my j-pac plugged in on to my usb and vga on my laptop. when i checked windows vista said my second monitor is not plugged in i am thinking it must be a driver or something   :banghead:
CheffoJeffo
Re: frontends
« Reply #9 on: August 21, 2007, 06:48:38 pm »
Well, wait a second ... you're trying to drive an arcade monitor off of a notebook VGA ?
While I'm pretty sure that I can futz my video drivers to produce a 15Khz signal from one of my notebooks (and, quite frankly, I won't bother to try), that is far from a foregone conclusion for all notebooks.
Before we get into what you need, you should tell us what you have ... I am guessing:
JPac (OK, not much of a guess)
Standard Res Arcade Monitor
If that is the case, then you need to be able to push a signal at 15Khz, not 31Khz (VGA). The JPac does not do this conversion for you.
Working: Not Enough
Projects: Too Many
Progress: None
ahofle
    • Arcade Ambience Project
Re: frontends
« Reply #10 on: August 21, 2007, 07:03:31 pm »
loadman
    • MaLa
Re: frontends
« Reply #11 on: August 21, 2007, 07:18:47 pm »
And we wanted to help you but we didn't understand the question.   :dunno
Anyway...... Good luck with your project :D
« Last Edit: August 22, 2007, 02:08:06 am by loadman »
Dire Radiant
  • Cor, chief!
Re: frontends
« Reply #12 on: August 22, 2007, 01:50:02 am »
First case of dyslexia I've ever seen that only has the effect of removing all punctuation while leaving perfect spelling.
killerkilley
Re: frontends
« Reply #13 on: August 22, 2007, 02:42:40 pm »
To dire have you noticed the spell check at the bottom of the page
killerkilley
Re: frontends
« Reply #14 on: August 22, 2007, 02:47:10 pm »
Thanks guy's. Its only temp on my laptop until i get everything i need. Thanks again ;D
