Author Topic: Its snowing in my arcade monitor.  (Read 1609 times)
kenster2001
  • Last login:September 02, 2007, 03:50:54 am
« on: August 18, 2007, 02:33:52 am »
I recently bought a working arcade cabinet with a 25" monitor and a 1 slot MVS. It appears to be a conversion. The monitor is marked Zenith.
I noticed that after warming up, I get weird white noise on black backgrounds. Its not too bad but Its a bit of an annoyance.
I thought it was some kind of interference from the marquee light, but it uses incandescent bulbs.
This problem is accompanied by a soft buzzing sound emanating from the back of the monitor. None of the caps are obviously bulged or leaking, and I checked for sparks on the flyback.
Could this be fixed by something as simple as adding a ferrite to the RGB input, or does this seem more like a problem with the monitor?
Thanks in advance.
Ken Layton
  • Guru
  • Technician
Re: Its snowing in my arcade monitor.
« Reply #1 on: August 18, 2007, 10:59:07 am »
Read this first:
http://forum.arcadecontrols.com/index.php?topic=62016.0
Now install a capkit in the monitor. If problem persists, then also recap the gameboard power supply.
