Author Topic: So with an iPac2, an OptiPac and a 3-sided cocktail...  (Read 2030 times)
  • Last login:Yesterday at 02:13:29 pm
« on: August 16, 2007, 12:38:31 pm »
Is there any way to set up my cabinet so I have separate lists for vertical games and horizontal games that display properly depending on what controls you are using?
I'm going to be "fixing" my cocktail table over the next few weeks and I'd like to finally sort this out.  I'm thinking of installing MaLa and bringing the roms up to date... am I on the right track?
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
Re: So with an iPac2, an OptiPac and a 3-sided cocktail...
« Reply #1 on: August 16, 2007, 01:15:03 pm »
absolutely.
mala most certainly can flip the orientation of the screen and/or switch lists depending on who is using the controls at the time.
-jeff!
« Reply #2 on: August 16, 2007, 03:59:51 pm »
absolutely.
-jeff!
But how will it know?  Is it based on the game list currently displayed?  My P1 and P3 joysticks are each wired to the same place on the iPac2...
loadman
    • MaLa
« Reply #3 on: August 16, 2007, 06:19:03 pm »
absolutely.
-jeff!
Yes, There is an option to have MaLa rotate depending on the current game list
« Reply #4 on: August 16, 2007, 08:20:20 pm »
Damn.  MaLa rules.  Thanks loadman - I'm going to hopefully do some tweaking to the old cab this weekend and try and get MaLa up and running...
loadman
    • MaLa
« Reply #5 on: August 16, 2007, 09:33:43 pm »
Cool...  There are a few rotation options
Depending on what you like and how you have wired your controls will determine the method you choose.
I personally lke having my controls wired up seperatly and have MaLa flip around to what controls are touched.
Also having my controls wired up seperatly is cool for a game like 'demolition derby' beacuse players from all around the table can join in the game.
Have a play :cheers:
« Last Edit: August 16, 2007, 09:57:05 pm by loadman »
« Reply #6 on: August 16, 2007, 10:32:54 pm »
This is how I want to set it up but I can't unless I get an iPac4, correct?
loadman
    • MaLa
« Reply #7 on: August 16, 2007, 10:40:24 pm »
Well I get away with it with a standad I-pac (3 sets of controls) but I have only allocated 3 buttons per player.
« Reply #8 on: August 16, 2007, 11:19:11 pm »
Ahhh, yeah - I have 3 buttons per player on the ends but the long side I use 6 for each player...  I've thought about ordering an ipac4 and swapping it out with my ipac2 and using that in another cab... maybe I'll do that eventually...
