Author Topic: WG k7000 woes, general readings needed..  (Read 1712 times)
segasonicfan
  • Last login:April 12, 2020, 02:34:26 am
« on: August 15, 2007, 10:13:40 pm »
Ok I have 5 WG K7000 chassis I have obtained cheap from several sources and I am trying to get my original 25" chassis working.  I've gone through the service manual and have bought replacement ICs and parts for most everything.  There is only a couple things I need to know from someone who has a working chassis or better knowledge:
1) Does pin 4 of the STR3132 voltage converter really output ~130v?  This is what the service manual says but all my boards read ~169v.  I checked closer for a short between pins 1 (input) and 4 (output) but there wasn't a short- there's just that large heat sinked 220ohm resistor across these pins.  So I am pretty darn confused on that one...
I've also been trying to use Q10 as a reference since the collector voltage is supposed to be ~40v according  to the service manual.  Is this correct as well?
Many thanks in advance,
-Segasonicfan
Totaly FuRy
  • Newbie
  • Last login:August 16, 2007, 11:07:05 am
Re: WG k7000 woes, general readings needed..
« Reply #1 on: August 16, 2007, 11:01:10 am »
hi, your STR is probably fried the voltage that you should get is the three last number of the reference 132V in your case.
mine is an STR30130 for 130 V and K7000 service book tell STR30123 and 123V on board.
ps: sorry for poor english i'am french.
« Last Edit: August 16, 2007, 11:07:05 am by Totaly FuRy »
segasonicfan
« Reply #2 on: August 18, 2007, 08:47:21 pm »
Thanks for the info :)  The weird thing is if I disconnect the huge resistor across pins 4 and 1 it does read out ~132v.  Any idea why this is?  Thanks for the help!
-Segasonicfan
