Author Topic: Can you hook TT2 x-axis to U360 x-axis?  (Read 1221 times)
rodneycrystal
  • Last login:August 01, 2012, 12:20:12 pm
« on: August 15, 2007, 09:32:39 pm »
Hi, I know this is a wierd question but I was wondering if it is possible to hook the x-axis of the turbo twist 2 to the x-axis of the ultimarc 360 through some sort of software configuration? If not, how about hard wiring it somehow? The reason I want to do this is for non emulated regular pc games. I am using ppjoy to create a virtual joystick and then use ppjoymouse to map the x-axis to the virtual joystick. This works well in some games like trackmania and hydro thunder. However, games like need for speed most wanted won't recongize my virtual joystick but it will recognize the u360. This is where it would be good to map the axis to the u360. I hope this makes sense.
