Author Topic: light gun act labs or topgun....  (Read 2016 times)
zabrin
  • Last login:February 03, 2025, 08:32:41 am
« on: August 13, 2007, 07:07:29 pm »
Please forgive another light gun topic.
I have read the 45 page topgun topic and found it a bit confusing actually. Here is my situation. I run win98se for my cab and smogs driver isn't that win98 friendly (not a dig on smog, my fault for using an outdated OS, and to say thanks for all his hard work and effort). What I do not want is to have to play with the drivers all the time. I need something easy. I have two daughters that already suck the life out of me :). I just want to make sure that when they turn on the arcade the guns work. I don't want to get a call at work "the guns are not working again". I'm sure we all have been through it :).
So my question is for simplicity, which one is better. I know Act Labs are a lot more but if it saves some headaches it might be worth it.  Thanks....
Z.
tba
  • Last login:July 21, 2010, 12:27:08 am
Re: light gun act labs or topgun....
« Reply #1 on: August 13, 2007, 11:35:42 pm »
well most people use smogs driver for the LCD top guns, as they seem to work best. i haven't heard much good about the act labs guns either though, possibly more stable but there are lots of compatibility issues depending on what TV you use.
another option i don't know if you have tried is Acorns driver... it is a little more win98 friendly. get it here: http://www.guncon2driver.com/  it is also a good resource for lightgun information on the forms.
good luck.
zabrin
« Reply #2 on: August 14, 2007, 09:00:52 pm »
Thanks...I will look into that!
Z.
