Author Topic: Topguns locking up mame on exit  (Read 1119 times)
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
« on: August 09, 2007, 10:38:35 pm »
I recently purchased two lcd topguns and have them all hooked up in my cab.  Since their installation I have been getting sporadic lockups when I exit games.  Below is what I'm running:
Windows XP
Mame 116
Smog Guncon2 driver .9b6
mamewah 1.62b13
mame.ini
mouse                          1
joystick                         0
lightgun                        1
dual_lightgun               1
offscreen_reload          1
Also tried mame.ini
mouse                         1
joystick                        0
lightgun                       0
dual_lightgun               0
offscreen_reload          0
I was originally running 113 but it was doing the same thing so I tried jumping to 116 to see if it would correct the problems didn't seem to help.  First noticed when playing xmen vs street fighter.  If I have the guns plugged in at least half the time when you exit it will lockup mame.  If I have the guns unplugged didn't have one lockup.  I also tried with and without mamewah.  Didn't make any difference if guns were plugged in it would sporadically lockup on exit.  I have only tried smog's driver I couldn't get the ems 3.2 drivers on the cd to work they always failed to load.  Anybody have any ideas on what to try next?
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
brock.sampson
Re: Topguns locking up mame on exit
« Reply #1 on: August 14, 2007, 06:30:31 pm »
Jumping up to mame .118 fixed the lockup problems.
Cananas
  • Last login:August 27, 2017, 07:39:03 am
  • and the seventh day... PacMan was created
« Reply #2 on: August 15, 2007, 06:11:02 am »
Yes. MAMEs from 112u? to 117 had a problem with the multithreading enabled and LCDTopGun plugged. Since 117u1, with the new Control  Input code, this bug has dissapeared and all work correctly.
