Author Topic: Sentinel (Again)  (Read 1073 times)
Normski-MRN
  • Newbie
  • Last login:August 08, 2007, 09:09:06 am
Sentinel (Again)
« on: August 08, 2007, 08:34:37 am »
I want to wire (a fully working) Sentinel 30/35 box into my winipac switch. No before doing this I want to check I have go it working off +12v and ground the Parallel Interface shows:
Pin 1 - COM A
Pin 2 - A.1
Pin 3 - NC
Pin 4 - A.2
Pin 5 - A.3
Pin 6 - Select
Pin 7 - A.4
Pin 8 - I.4
Pin 9 - 12v
Pin 10 - 0V
Pin 11 - I.3
Pin 12 - I.2
Pin 13 - I.1
Pin 14 I.5,6
Pin 14 I.7,8
Now I have wired Pin 9 to 12v and Pin 10 to 0v (GND) and Pin 1 to 12v
If I do this all coins reject.
If I disconnect Pin 1, the first coin accepts and further coins are rejected.
Question: How do I wire Pin 1
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
Re: Sentinel (Again)
« Reply #1 on: August 08, 2007, 10:36:18 am »
I think that would go to the ground (or common) on your ipac.
