Author Topic: 5/8 Particle underlayment board?  (Read 4083 times)
str1der
  • Last login:March 04, 2021, 04:35:31 pm
  • Live it!
« on: April 26, 2003, 05:48:26 pm »
I've been trying to find 5/8 MDF but it's not in my area. I did find 5/8 particle underlayment board. It seems pretty good and has a smooth surface to it. Has anyone used this for a cabinet? Any opinions on this material? Thanks.
BobA
  • What Me Worry?
Re:5/8 Particle underlayment board?
« Reply #1 on: April 26, 2003, 08:22:01 pm »
Material would probably be OK but isnt it in smaller sizes.  Floor underlay are usually about 4 by 4.
BobA
Ledbetter
  • Last login:March 01, 2005, 08:13:19 pm
« Reply #2 on: April 26, 2003, 08:37:24 pm »
  I would only use particle board if your going to cover your cab with laminate.
  • Last login:Yesterday at 10:10:00 pm
« Reply #3 on: April 26, 2003, 09:44:25 pm »
5/8 th is the thickness, not the dimensions :)
As it's particle board and 5/8 th's that is two steps in the wrong direction.  3/4 inch plywood would probably be better if you can't find mdf.  Either way, you going to have to cover it with something if you don't want a textured finish, but at least with plywood it's sturdy, won't chip and the right width for t-molding.
str1der
  • Live it!
« Reply #4 on: April 26, 2003, 10:06:21 pm »
It's in 4X8 sheets and the sides are as smooth as MDF. I can get 3/4" MDF but I always thought 5/8" was perferable. From the true cabinets I've seen in arcades most of them seem to be 5/8 " particle board. Isn't the Melamine that people refer to a particle board? It doesn't seem as fine as MDF. It just seems  like the 3/4" MDF is an overkill as far as weight goes.
SNAAAKE
  • -Banned-
  • Last login:July 21, 2004, 03:44:18 am
  • Banned for abusive postings.
« Reply #5 on: April 27, 2003, 04:22:54 am »
What overkill?  ???
Most cabinets uses 3/4" wood.Only way I would use 5/8" particle board if I am gonna use laminate.
Trust me...ya dont wanna paint particle board(I am telling you :-[).
I say just buy some 3/4" mdf and start working !  8)
Sprucemoose
  • Last login:March 23, 2009, 03:56:10 pm
  • You Spent How Much?!
« Reply #6 on: April 28, 2003, 09:38:05 am »
I have used both and would recommend MDF.  It is very heavy, but easy to work with and paint.
BobA
  • What Me Worry?
« Reply #7 on: April 28, 2003, 10:29:14 am »
Yes Howard I know 5/8 is thickness.  ;) At the Home Depot near me floor underlay boards are available in 4 by 4 size only.  Sort of half sheet squares.
If it is in 4/8 sheets and you feel it is smooth enough for a paint finish you can probably make do with it.  You will probably have to primer and paint as the surface will absorb paint more then MDF.
If you are looking for a really smooth finish then go MDF
The Melamine sheets are particle board coated with a melamine veneer.
In your first post you didnt say that your could get 3/4 MDF just that your could not get 5/8.   Go with the 3/4 MDF and you will not have to worry about finnish problems.
BobA
Lilwolf
« Reply #8 on: April 28, 2003, 10:32:37 am »
Before buying 5/8's, consider if you will need TMolding and see how much more it will be.  3/4 seems to be the standard for both cabinets AND tmolding... and if 5/8 was a special order, it might end up being much more expensive.
3/4 will be strong enough for you btw.
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
« Reply #9 on: April 28, 2003, 01:50:18 pm »
Don't be fooled. To the touch, the smoothness of particle board and MDF seem very similar, but they aren't. Throw a coat of paint on them and you will see what I mean. I don't know if it is due to absorbtion or not, but particle board becomes extremely rough with paint on it. MDF does not.
« Last Edit: April 28, 2003, 01:50:45 pm by FractalWalk »
saint ganked my avatar.
str1der
  • Live it!
« Reply #10 on: April 28, 2003, 04:28:05 pm »
Ok, thanks guys
