Author Topic: Are the LEDS that plug right into a power supply?  (Read 1126 times)
shawnzilla
  • Last login:May 05, 2022, 12:01:55 pm
« on: April 25, 2003, 02:53:39 pm »
Forgive me if this question has been asked 1000 times, but are there LEDs that plug directly into a computer power supply? If so, are they long enough to reach from my computer to the inside of my control panel? (assuming I'm using a LUSID clone)?
BobA
  • What Me Worry?
Re:Are the LEDS that plug right into a power supply?
« Reply #1 on: April 25, 2003, 03:37:56 pm »
Most LED's need a series dropping resistor when connected to a power supply.  The value of the resistor depends on the voltage drop of the LED and the power supply voltage.  There have been a couple of threads that give links to calculators to figure this out. The LED and dropping resistor can be place anywhere on your cabinet as long as you provide enough wire.  You can get wired LEDs with dropping resistors already installed but these are usually alot more expensive then fabricating your own wire leads and usually dont the proper length of wire anyway.
All Electronics has alot of surplus LED stuff that might be of interest to you.
http://www.allcorp.com
BobA
« Last Edit: April 25, 2003, 03:41:07 pm by BobA »
aj6500
  • Last login:July 29, 2003, 06:17:31 am
  • Does this rash look contagious?
« Reply #2 on: April 25, 2003, 04:10:08 pm »
Led's need 5 volts.  I believe the power supply puts out 5 volts throught the red wires going to the HD's.  Double check w/a voltometer.
They say patience is a virtue, and ignorance is bliss.  So I guess you can have a pretty good life if you're stupid and don't mind waiting around.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #3 on: April 25, 2003, 04:25:50 pm »
I bet if you poked aoround the case modding stores you'd find lots of glowy flashey things that plug into the standard ide power plug thingie *shrug*
just a hint.. I have no specific link for you =P
rampy
BobA
  • What Me Worry?
« Reply #4 on: April 25, 2003, 04:37:08 pm »
Plug a regular red LED into a 5 V supply and you will get a very bright LED for a very short time.  A red LED has about a 1.7 to 2V drop so an additional dropping resistor is needed. A 10 ma red LED requires 300ohms or A 20 ma red LED requires 150 ohms.  This must be calculated for proper operation unless the LED has a built in resistor or voltage regulator.
The LEDs that plug into your HD indicator and Power indicator pins on the mother board are probably already limited at the motherboard.
Here is the LED calculator thread.
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=5669;start=0
BobA
« Last Edit: April 25, 2003, 04:39:48 pm by BobA »
