March 19, 2026, 11:35:49 am
Cut coin door hole, then laminate, then flush trim. That is the easisest/neatest way to do it. If you laminate first, then you risk tearing up the laminate. If you cut the laminate first, you will most likely misalign the laminate.
Thanks guys...So if I read that correctly.. 1) Cut hole in panel2) Laminate panel3) use a flush trim router bitMy only follow up questions would be do I start the flush trim bit by drilling a hole in the laminate and then using the router, or cutting out a larger section in the laminate and route it?
you don't have a hole in the panel now? How about laminate it first, and then cut the hole out of the panel and laminate at the same time?
