Author Topic: Looking for a NBA jam 5k sound pot w wiring?  (Read 8068 times)
kjoel0123
  • Last login:January 07, 2012, 09:57:19 am
  • Cabs for sale - Please see my flickr page for all
« on: July 24, 2007, 08:44:59 am »
So i went to radio shack and picked up a 5k pot and wired it up. Sound crackles and does not work. Seems to be the wrong pot. So I still need one to play this game. Anyone have a 5k pot thats wired? I would have never purchased this board if I knew about this issue..
Dedicated Cabaret cabs I currently own:
Neo Geo/ GT Complete/Mspac galaga reunion
full size cabs: Playchoice 10 Single Monitor/Nicktoons Racing/Junior King Cocktail/ Super Punchout/
Pins- Revenge From Mars/ Black Rose/ LW3
For Sale/ Trade: Digdug in Ireland Cab/83' Chexx Hockey/Battlezone/PC10 Bartop with 6 games
Check out http://www.flickr.com/kjarcade <--not updated
Q*Bert_OP
  • Oh yes, we did!
Re: Looking for a NBA jam 5k sound pot w wiring?
« Reply #1 on: July 24, 2007, 11:19:29 am »
I think that you actually need a 50k ohm pot...
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #2 on: July 24, 2007, 09:34:18 pm »
Or you wired it wrong.
kjoel0123
« Reply #3 on: July 24, 2007, 11:44:48 pm »
If I can get the wiring diagram for this that would be great. I tried every pin and no success. There are only 3 pins on the P5 connector. I even matched my defender cab pot wiring to no avail. Just seemed like the pot was incorrect. Not sure what is correct.. I will try a 50 ohm pot if no one can verify.
« Last Edit: July 24, 2007, 11:57:13 pm by kjoel0123 »
Q*Bert_OP
  • Oh yes, we did!
« Reply #4 on: July 25, 2007, 12:09:25 am »
kjoel0123
« Reply #5 on: July 25, 2007, 08:24:36 am »
Great thanks
Does anyone know where the connections go on the pot side? There are 3 connections on the pot- which 2 are used?
Kevin Mullins
    • Me on Myspace
« Reply #6 on: July 25, 2007, 09:13:12 pm »
Is this in an actual NBA Jam cabinet or some other JAMMA cab?
Scroll down a bit on this page for your wiring question: http://sound.westhost.com/pots.htm
kjoel0123
« Reply #7 on: July 25, 2007, 11:15:56 pm »
Wired it as stated . Did a nice clean solder job and plugged it in the board and it dont work and now niether does this damn board. Piece of crap !!
Kevin Mullins
    • Me on Myspace
« Reply #8 on: July 25, 2007, 11:33:45 pm »
Sounds like you need to double check all your connectors....... the ribbon cable, JAMMA harness, etc.
Do a clean re-seat of all the socketed chips, then go from there.
Q*Bert_OP
  • Oh yes, we did!
« Reply #9 on: July 26, 2007, 01:13:48 am »
Piece of crap !!
That's Midway for ya!
kjoel0123
« Reply #10 on: July 26, 2007, 08:05:49 am »
I'll try again tonight and try to reset the board. Last night I think that I would have thrown the board like a frisbee.
SavannahLion
« Reply #11 on: July 26, 2007, 03:31:42 pm »
Did that once. I had to trek through five feet of freshly fallen snow around the back the house and down the hill when I realized that A) I really needed it and B) it wasn't mine.
northerngames
  • Trade Count: (+18)
« Reply #12 on: July 27, 2007, 09:58:10 am »
usually ground is in the middle and the volume +/- signals are on the ends same thing with duel color 3 legged led lights.
the + signal should be on the right side if your facing the actual turn knob the right pin should be + and the left should be - and the middle as gound/nuetral this I am not 100% sure becuase of your pot type but most electroncs I ever used volume up is always turn it right and to turn it down turn it left  :dunno
« Last Edit: July 27, 2007, 10:11:16 am by northerngames »
kjoel0123
« Reply #13 on: July 27, 2007, 03:55:10 pm »
I looked at a schematic and the ground was on the left, thats how i wired it. Now I know that it was incorrect for this pot. I wil try your wiring scheme. hell the board dont work so what do I have to lose. I will try to reset it this weekend unless my cap kit comes into play for my defender cab.
northerngames
« Reply #14 on: July 27, 2007, 04:54:01 pm »
well if the ground was in the wrong spot after all it would not work at all becuase the signals were not getting any ground also I check a few of my authentic arcade manuals and they have all of the down as 5k volume pot there called a regular 5k pot may not do it and pretty sure a 50k would take some juice lol so make sure your using a 5k volume pot only.
hopefully if you were wrong sending the signal and ground in a reversed manner did not harm anything else this I cannot tell you but if it did and you find a spot were it blew I could probably fix it but try the correct pot first and see what happens.
EDIT: in one of the links above it does state that pin 1 is grouns pin 3 is input and pin 2 is output but down further is also shows and state's that on cetian type's the ground can be in the middle like I was saying I will see if I have any wiring schematics for any games and see if it show how there wire in.
« Last Edit: July 27, 2007, 05:04:36 pm by northerngames »
kjoel0123
« Reply #15 on: July 27, 2007, 11:08:33 pm »
On the back of the pot it is engraved 5k. I will work on this board tomorow as tonight I recapped a monitor.  I will keep you posted !
kjoel0123
« Reply #16 on: July 28, 2007, 08:41:15 am »
I wired it as stated . Here is what is happening. When I turn the arcade on:
- It passes a rom board tests
- Game starts showing game play rules
- Game instantly goes to a black screen within 10 seconds
- Tried with and without the sound pot to no avail
I will try without the sound board connected next, Any ideas
Without the sound board the game plays fine. Now I either have bad roms on the board or the board needs to be replaced. Anyone know where to get a working sound board for an NBA jam? I just purchased this from another member here and it never played sound since I just owned it.
« Last Edit: July 28, 2007, 08:49:51 am by kjoel0123 »
