Author Topic: Jamma Moniter question  (Read 1507 times)
red_johnny
  • Last login:June 03, 2011, 02:35:17 pm
« on: July 23, 2007, 09:39:21 pm »
I have a 33" cabinet that should house a 33" moniter.  I would like to put in a 36" moniter and my question is......can I wire in a regular TV into the houseing?  If so how does that work?  I know i have to remove the shell off of the TV and discharge it then build a bracket around it.  I am not sure how to wire it in from that point with power and video.  TIA
Kevin Mullins
    • Me on Myspace
Re: Jamma Moniter question
« Reply #1 on: July 23, 2007, 09:44:07 pm »
It all depends on what you actually plan on running on it.
A JAMMA setup I assume from the post title.
If that's the case, then no. Not without an RGB to NTSC type converter.
« Last Edit: July 23, 2007, 09:46:42 pm by Kevin Mullins »
red_johnny
« Reply #2 on: July 23, 2007, 09:51:57 pm »
Yes, I will be running Jamma games on it.  I am getting a Jamma 4 to 1 adapter so that I can have 4 games running off of it.  So where could I get these converters from?  Thanks!
Kevin Mullins
    • Me on Myspace
« Reply #3 on: July 23, 2007, 09:56:20 pm »
Here's just ONE example.
http://www.twobits.com/RGB/
Google - "RGB to NTSC"
There's many out there.
I don't have a particular one to reccomend.
Maybe someone else on here might.
red_johnny
« Reply #4 on: July 23, 2007, 09:59:16 pm »
Oh, ok.  Thank you :notworthy:
BobA
  • What Me Worry?
« Reply #5 on: July 23, 2007, 11:22:14 pm »
Here is another source for an RGB to NTSC converter.  These are used in alot of units and work very well.
http://www.jrok.com/hardware/RGB.html
