Author Topic: Can someone please tell me whats wrong with my police trainer board?  (Read 3524 times)
berlincam86
  • Last login:January 30, 2020, 10:03:28 am
  • I can't wait to build my first cabinet!
The picture looks like this but it still plays and has sound. Please tell me someone had this same problem and how to fix it.
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re: Can someone please tell me whats wrong with my police trainer board?
« Reply #1 on: July 21, 2007, 08:19:31 pm »
Looks out of sync.  Have you tried adjusting the monitor?
berlincam86
« Reply #2 on: July 21, 2007, 08:21:58 pm »
yes ive tried that.
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
« Reply #3 on: July 22, 2007, 04:02:45 am »
Also check to make sure all the chips are seated well on the PCB.
Could very well be a monitor issue as well.
Did it just stop working or did you pick it up this way?
berlincam86
« Reply #4 on: July 22, 2007, 09:15:29 am »
I picked it up like this. Ive tried 2 sets of chips. Differant monitors and differant power supplies. All made the same picture.
Q*Bert_OP
  • Oh yes, we did!
« Reply #5 on: July 22, 2007, 12:29:24 pm »
Have you swaped Processors yet? (If you can)
berlincam86
« Reply #6 on: July 22, 2007, 02:37:14 pm »
no i havent tried that but why would that make it play like it is. The game plays fine its just the video is screwy. I have changed everything that i can unplug and plug back in. I havent tried to solder or unsolder anything. Mostly everything is surface mount.
grantspain
« Reply #7 on: July 22, 2007, 02:40:50 pm »
thats a strange screen,its like none of the colours are syncing at all.
what monitor are you using and what are the connections pinouts you are using?
have you tried the cab with a different game board?
berlincam86
« Reply #8 on: July 22, 2007, 02:43:58 pm »
Well so far im using a test station i built with a rgb to rca converter to play it on my tv.. But where i got it from it played the same on a differant monitor. Im using standard jamma pinouts.
Kevin Mullins
    • Me on Myspace
« Reply #9 on: July 22, 2007, 06:00:27 pm »
KLOV says Police Trainer is standard resolution.... can anyone verify if that is correct?
(I thought it was a medium res game)
Definitly a sync issue.
Whether it's due to wrong resolution settings etc or a bad video output on the boardset I'm not sure.
SirPeale
« Reply #10 on: July 22, 2007, 06:39:46 pm »
Definitely standard res.  Most of the ones the company I worked for had were in Mortal Kombat cabs with K7000s.
berlincam86
« Reply #11 on: July 22, 2007, 06:41:45 pm »
there is a polarity switch on the board  for sync but it does nothing.
berlincam86
« Reply #12 on: July 22, 2007, 11:21:48 pm »
Ok I fixed it. It was a combination of the sync switch and the voltage. I switched the sync switch and played with the 5 volt adjust on the power supply and after a couple of minuites its working great. Thanks for your guys help.
berlincam86
« Reply #13 on: July 23, 2007, 12:19:09 am »
Ok nevermind i have a break somewhere because when i touch or move the board it goes all fuzzy. I can see nothing but when i move it again or push in the right spot on the board it goes back clear. So i have to find the break or loose joint.
