February 01, 2026, 10:52:37 pm
Congrats on the great score!Check that interlock switch. On most you can actually pull it out instead of taping it closed. Pulling it out is intended for maintenance when the door's open.
Where are you located at?Hawk
Quote from: Hawk Daddy on July 15, 2007, 10:27:40 pmWhere are you located at?HawkWhat's your EXACT address ?
Wow! So how far along is your pac project? I'd say scrap it if you can.However, if you don't really want this one, you could just turn around and sell it now to make a few hundred dollars.
That's pretty sweet.Most cabs I've dealt with that have interlock switches (I'm curious when ppl stopped using them) have them either removed entirely or swiveled so they're on all the time with the plunger pulled out.
