Author Topic: Feel good about my speaker situation.  (Read 2319 times)
Sir Auros
  • Last login:December 06, 2012, 12:13:00 pm
    • The Transformers Archive
« on: July 13, 2007, 12:41:16 am »
I was going to take out the original speakers and put in a pair of computer speakers in the NFL Blitz cabinet I'm converting, but once I saw how light slipped through the grill, I decided, why waste the originals?
I found a cheap pair of Kinyo speakers ($5.99) at Big Lots, and mostly disassembled them tonight, and spliced the speaker wires to the original wires. I put the originals back in the cabinet, turned the speakers on, and listened to a few songs on my ipod. The sound quality was fine, and it looks like this will work.
I did run into two problems. One is that I can't get the power cable out of the back of the right speaker case unless I break or cut it. Not keen on getting shards of plastic to the groin, so anyone know a good way to cut through plastic? I'm considering heating it up with a hair dryer and taking some sort of blade to it.
The other problem is that I can't remove the pcb board from the piece of plastic that has the volume knob attached without removing the volume knob. I could get some pliers and yank or something, but I would prefer to save the knob for reattachment when I want to move the volume control to the control panel.
EDIT - Now have a pic. It's messy, but I'll clean it up when I'm ready to use it.
« Last Edit: July 13, 2007, 12:58:23 am by Sir Auros »
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
Re: Feel good about my speaker situation.
« Reply #1 on: July 13, 2007, 05:46:27 am »
Assuming you have a terminal block or something in the arcade cab, then just chop off the plug, pull the wire thru and crimp on a couple of QC's or whatver your terminal block needs, saves the space of a socket, otherwise put a new plug on the end of the wire.
Or smash the speaker case or use a nibbler so that its relativly safe.
MPTech
  • Last login:January 05, 2025, 03:58:54 pm
  • UltimateArcade completed!
« Reply #2 on: July 13, 2007, 12:23:08 pm »
If you don't have a Dremel Tool, it would be a great tool for cutting the case you describe.  Buy a cutting disk (they are replaceable.  These will cut through anything (I cut a heavy-duty Master Padlock last weekend) so plastic is like butter.
MPTech
   Better living thru technology!   ;-)
Sir Auros
« Reply #3 on: July 15, 2007, 12:03:17 am »
Tinsnips actually tore through the back of the speaker, and I think I'm just going to mount that hole faceplate into the lip under my CP. The hole could be cut and the screw mounts are already there, so...
