Author Topic: Should be an easy one for all of you  (Read 1196 times)
smackifilia
  • Last login:July 24, 2007, 03:29:22 pm
« on: July 12, 2007, 06:15:55 pm »
Is there any way for me have mame bypass the warning and info screens as well as load up a save slot when it loads a rom?  I.E. be like never unplugging the machine and saving the hi-scores?
-smackifilia
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Should be an easy one for all of you
« Reply #1 on: July 12, 2007, 07:02:58 pm »
See the hi-score patch stickied at the top of this forum.  It also removes many of the warning/info screens.
First, manually create a save state that you want to load automatically.  Then create an ini file with the same name as the rom file and put it into the ini subfolder under mame.  The ini file should have at least the following if you saved it in slot 1.
state             1
The game will then automatically load save state number 1 on game startup.
smackifilia
« Reply #2 on: July 12, 2007, 10:03:36 pm »
Thanks! My bad for missing that in the stickies
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: July 13, 2007, 12:53:34 pm »
... load up a save slot when it loads a rom?  I.E. be like never unplugging the machine and saving the hi-scores?
Enable autosave.
Quote from mame/docs/windows.txt:
-[no]autosave
   When enabled, automatically creates a save state file when exiting MAME
   and automatically attempts to reload it when later starting MAME with
   the same game. This only works for games that have explicitly enabled
   save state support in their driver. The default is OFF (-noautosave).
Of course, this only works if mame supports savestate from that game.
Robin
Knowledge is Power
