Author Topic: Correct usage of MaLa Tree?  (Read 4022 times)
Anubis_au
  • Last login:January 15, 2023, 10:12:32 pm
  • Ever danced with the Devil in the pale moonlight?
« on: July 07, 2007, 12:10:35 am »
Hi all
I've been planning how I want my MaLa menu structure to be in my arcade cab. I've done up a little drawing to illustrate.
For Daphne, Future and Visual Pinballs, I'd want MaLa to show all the games/ tables, but for MAME I want to go one further, and have a cut down favourites menu with the option of going to a full menu. I'm also thinking of a separate vertical games screen if I end up going the path of a rotating monitor.
Is this the sort of thing that you use MaLa Tree for? Otherwise, is there another way to implement this in MaLa?
« Last Edit: July 07, 2007, 12:18:02 am by Anubis_au »
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
Re: Correct usage of MaLa Tree?
« Reply #1 on: July 07, 2007, 04:31:14 pm »
There's no real "correct" way to use the Tree..  you can pretty much use it how you see fit.
Personally, since you've made a section for "Arcade Games", I would simplify the tree a bit more under that section.
                                 Arcade games
Favorites         Laserdisc                Vertical              All
In my opinion, there's no need to create a seperate Daphne and MAME section, since they're all just arcade games and I like to keep the whole "software" aspect of it all hidden to the casual player.
But again, I should reiterate that it's ultimately a personal choice...  In the end, it's up to you to decide how you want to set everything up..
« Last Edit: July 07, 2007, 04:50:34 pm by Organic Jerk »
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
Anubis_au
« Reply #2 on: July 07, 2007, 08:08:19 pm »
Organic, you are right... games are games are games...  Laserdisc games can co-exist with MAME :P
Btw went to your website... love your UI screenshots... that looks awesome! (and forgive me for saying so, but I prefer some of your older CP layouts to the tech one... sorry)
loadman
    • MaLa
« Reply #3 on: July 08, 2007, 05:23:49 am »
It would be super- cool if one of you would share your finidings on the Wiki page
http://wiki.arcadecontrols.com/wiki/Mala_Tree
Anubis_au
« Reply #4 on: July 09, 2007, 10:50:58 pm »
Loadman, if I get the MaLa tree working I'll happily document it for the wiki, cos its threadbare at the moment, as you know :P
Hence I have to ask if I even have the right use of it!!! :P
