Author Topic: pot wires steering wheel atari  (Read 2024 times)
thunder-rolling
  • Last login:August 25, 2007, 06:23:47 pm
« on: July 05, 2007, 06:50:53 pm »
Hi,
I have an Atari steering wheel, pulled from a Final Lap cab. Is it safe to say: black wire = ground, red wire = 5v and brown wire = signal?
hng
  • Last login:July 27, 2007, 02:07:23 pm
    • myspace
Re: pot wires steering wheel atari
« Reply #1 on: July 05, 2007, 11:22:33 pm »
only 3 wires?
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #2 on: July 05, 2007, 11:39:37 pm »
A wheel with a potentiometer on it (270 degree wheel) will have three wires.  An optical wheel (360 degree wheel) would have four.
On a pot, it's not ground, +5 and signal.  It's ground, other ground and wiper.
What are you planning to hook this thing up to?  Should be an A-Pac or an AKI, unless you're using a Dual Strike hack or similar.
thunder-rolling
« Reply #3 on: July 06, 2007, 01:22:40 am »
I'm using a dual strike hack. I see I've got the terminology down pat..
Zebidee
  • Last login:January 07, 2026, 10:22:02 am
« Reply #4 on: July 06, 2007, 09:51:10 pm »
NO!
For a pot, the 3 wires are:  Ground (probably BLACK), signal input (probably RED, pre-wiper) and signal output (post wiper).  Looking at the pot from the back, the three pins are:  GROUND - INPUT (ie 5v) - OUTPUT (signal, reduced voltage)
To use an apac, you'll need to determine the eletrical resistance rating of the pot by using a multimeter.
For more directions, look at the APAC page on Ultimarc.com.
Kremmit
  • - AHOTW -
« Reply #5 on: July 06, 2007, 10:14:03 pm »
Der.  For some reason I was picturing a pot wired up in more of a "balance knob" configuration.  Which was dumb, considering a steering wheel is not a balance knob.  And even at that, it's really a case of two inputs plus a wiper, not two ground plus a wiper.  Somebody smack me upside the head with a copy of Electronics for Dummies, please.
 :dizzy:
